Results 1 to 2 of 2
Thread: Well-X-Trol Tank Size
    DIY Junior Member garro14's Avatar
    May 2013
    Prosser, Washington
    Default Well-X-Trol Tank Size
    I have a 3/4 HP submersible pump that pumps 10 GPM and my pressure switch is set and 30/50. I currently have an old (1993ish) flotec 50 gallon bladder tank that I pretty sure is waterlogged. I drained all the water out turned off the pump and checked the air pressure. Nothing. So I aired it up to 28 psi. It won't last long so I'm going to get a new tank. I've done research and it seems the well-x-troll tanks are the best. Should I get the 44 gallon or the 62 gallon?
    Moderator valveman's Avatar
    Mar 2006
    Popcorn time!
    Or you could use a 4.5 gallon size tank with a Cycle Stop Valve, and actually solve the problem that caused the bladder to break in the first place.
    See this graphic for how it works.
    http://www.cyclestopvalves.com/simple/home.php
  1. changing my pressure switch on my well/trol tank
    By suzyQ in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-06-2013, 08:31 PM
  2. Well-X-Trol WX-102 Pressure tank issue!?? Need confirmation
    By Bassett72 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-14-2011, 07:23 AM
  3. Well-trol pressure tank wx 202 operating pressure question
    By tlpayne in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-04-2010, 03:02 AM
  4. Well-X-Trol tank capacity question
    By paullyboy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-18-2008, 09:29 AM
  5. Well X Trol Tank Question
    By GLH in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-07-2007, 06:48 AM
