Thread: Ox-Box, F1807, ProPex, and Sharkbite Crimper and Rings
    DIY Junior Member RPN's Avatar
    Oct 2012
    MO
    Default Ox-Box, F1807, ProPex, and Sharkbite Crimper and Rings
    I am getting close to doing this re-plumbing job that has been on my list for a couple of years now.
    A few rolls of AquaPex and a bunch of fittings should be here today. I have the Milwaukee ProPex tool on order.
    Let's talk washing machine boxes. I have seen the Sioux Chief Ox-Box recommended. It is available in a few termination styles - one of them being F1807 Pex.
    Soooo, some questions:
    1. I am assuming that the ProPex rings will not provide anywhere near enough pressure on an F18097 fitting (0.492" ProPex expansion fitting size vs 0.406" F1807 size). correct?
    2. I have a Sharkbite crimper and copper rings that I got to terminate some pex of unknown origin. Sharkbite (Cash Acme) claims that the tool and rings meet F1807 standards. Do you know of any issues using AquaPex (Pex-A) with ordinary copper crimp rings?
    3. Is it worth it to get the Ox-Box with the built in mini-arrestors?
    I tend to order the OX Box without the PEX adapters and solder on my own.
    I "always" install the box with the mini-resters. A lot less wear an tear on the hoses when the washer bangs on and off.
    Oct 2012
    MO
    Thank you so much for the quick reply. Should I use the normal ProPex copper stubs for the solder connection?
    ETA: Or, just use a ProPex female sweat and cut a stub from some type L. That would be $2.75 each vs around $10 for ProPex stubs.
    You can do either the male or the female.
    I normally just sweat on the males. You do have to be a bit careful when soldereing though. Too much and you can't get the plastic locking nut past it.
  1. Pex Crimp rings or Clamp rings....Which Preferred ?
    By Its.me.again in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-21-2012, 07:22 AM
  2. Two rings, or not two rings, that is the question.
    By SugarHollow in forum Toilet Forum discussions
    Last Post: 09-06-2012, 07:48 AM
  3. ProPex
    By pats' plumbing in forum HVAC Heating & Cooling
    Last Post: 06-30-2009, 09:41 PM
  4. Which PEX Crimper? PLEASE HELP!!!
    By rsmith99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-04-2008, 06:42 PM
  5. Crimper
    By chipshot in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-28-2005, 06:38 PM
