Results 1 to 2 of 2
Thread: P-trap operational limits ??
    DIY Member SH140's Avatar
    Jan 2013
    Vallejo, Ca.
    Default P-trap operational limits ??
    Getting ready to install plumbing for new tub install, and wanted to know ahead of time if there are any limitations when installing the p-trap. I know that the standard trap is a fairly tight radius. If need be, could a trap be made with two 90o elbows with a straight connecting pipe at the bottom ? if so how long can connecting pipe be so that the trap still functions correctly? (1", 3", 12" ???) If not, is it because the trap operates more efficiently with a tight turn in a shorter length?
    Also, where there will be no access to the plumbing after the tub goes in, is it better to use only glued joints in the ABS plumbing?
    Sep 2009
    Seattle. WA
    Built-up p-traps are generally made up of a 90 plus street 90. The short bend promotes "scouring", so sediment and deposits are minimized in the bend. The plumbing
    codes REQUIRE no-access drains to be made up of glued (solvent-welded) or other approved joints.
  1. LOW CFM effect and limits on evaporator/AC system ??
    By Jin in forum HVAC Heating & Cooling
    Last Post: 08-06-2012, 09:03 AM
  2. Breaker Wattage Limits
    By my3angels in forum Electrical Forum discussion & Blog
    Last Post: 07-29-2011, 11:28 AM
  3. Boiler not operating within Hi Lo limits
    By ut7351a in forum Boiler Forum
    Last Post: 12-08-2010, 01:14 PM
  4. How to check transformer operational
    By nothingeverworks in forum Electrical Forum discussion & Blog
    Last Post: 01-12-2010, 03:48 PM
  5. Advice on height limits of Washing Machine disposal pipe
    By barryhepburn in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-29-2006, 04:52 PM
