Results 1 to 6 of 6
Thread: Challenger PC266R pressure tank
    Retired Gpace1's Avatar
    Feb 2007
    Austin, TX
    Default Challenger PC266R pressure tank
    I just noticed a leak under my pressure tank in the garage. This tank was installed July 2006. The previous one (same model) was installed in 2002 and failed the same way. The leaking water is very rusty. Water pressure and quality in house is unaffected, so far. Are these tanks prone to this type of failure? Is there a better quality tank? I read somewhere that this tank has be replaced with a diaphragm type (FLX185PC266). Is this tank any better? I need some advise before I have someone come out and replace this tank. Thanks. Gene
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Well X Trol is the best
    Moderator valveman's Avatar
    Mar 2006
    I believe that PC266 is a diaphragm tank. You need to see if it is the tank or just a fitting that leaks. But if the tank itself is already rusted through, you might want to try a fiberglass one next time.
    Feb 2007
    Austin, TX
    Thanks to all replies. Had Associated Drilling out of Manchaca, Texas come out. The 5 year old Challenger had a rusted out welded "malleable" elbow leaking. I had them install another challenger "I" series (I85-PC266) with a stainless elbow. $900. out the door. Took them all of 30 minutes. But..... now I know how to do it. Thanks of again.
    Apr 2012
    ct
    $900.00 sounds like a very fair price to me
    Feb 2007
    Austin, TX
    Yes, I was very pleased. The labor was $150. for 2 men. No supplies. Shut pump power, drain tank, unscrew two pipes and drag the old one away. Reconnect new, check air and start filling while watching pressure switch. Done...
  1. Water hammer bouncing pressure gauge needle AFTER pressure tank fills
    By hawkhunter in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-27-2012, 10:35 AM
  2. Flexcon Challenger tank moved slightly
    By Flawell in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-05-2012, 10:41 PM
  3. why is a pressure tank with a bladder better than plain old steel pressure tank
    By fcbclan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-26-2012, 02:56 PM
  4. Convert propane tank to water pressure tank
    By jhv in forum Irrigation / Sprinkler Forum
    Last Post: 06-27-2008, 08:23 PM
  5. Bladder pressure tank vs standard pressure tank
    By brown13 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-06-2006, 07:18 AM
