Results 1 to 9 of 9
Thread: Plumbing new building, questions on PEX
    DIY Junior Member Jasong71's Avatar
    May 2013
    New Hampshire
    Default Plumbing new building, questions on PEX
    Hi,
    So I am an advanced DIY'er. I am renovated an older, 2-story gambrel building on my property. We are moving our daycare/preschool out to it. I have it down to the studs and will be insulating the entire first floor and adding a bathroom with 3 toilets in a straight line and 6 sinks total. Furthest distance between 2 sinks is about 20 feet.
    We are putting in a new septic and a drilled well. The well will go 150' to the house and then back 75' to the building. What considerations do i need to make for plumbing the fixtures.
    Also, it is sitting on posts on concrete footings, so there is no slab or basement. I am in the northeast and winter is cold. Would a box around the plumbing filled with expanding foam be enough to insulate the plumbing so it does not freeze? or is there a better way to do this?
    Aug 2009
    South*East
    No insulation creates heat and no matter how much of it you use without a heat source the pipes will freeze.
    I'm not a pro, but I have often wondered why when folks build a building that will have long hot water runs they do not put in a recirculation system so even the far units will have virtual instant hot water. I would certainly not use PEX when the walls are open and copper can be run without undue effort. but that my personal bias. I would suggest you make sure your pull all of the permits required and follow all build codes to the letter since this will be a commercial building and children will be involved in the use. There are many places you can err on these matters, so DIY may not be your smartest move.
    May 2013
    New Hampshire
    The expanding foam insulated box is the norm for up here and it does work. It can get to 20 below zero. I am not opposed to heat taping it either. Is there better option?
    May 2013
    New Hampshire
    Gary, thanks for the input. The furthest sink from the water heater is 15'. I did not think that was a long run, am I wrong about that? Would a recirculator really be that much of an improvement?
    I hear PEX is great and most builders up here are using it. I am not opposed to copper since that is what my experience is in, but I am interested in the PEX.
    I have pulled my permit and there are no local building codes, so I am following the National ones.
    In my expierence repairing frozen pipes over the decades, unless you temper the heat around the pipes, they will freeze. Bundled pipes in foam at 10 degrees don't know they can't freeze, they do. When we install pipes, we try to trap the warm inside air to keep them above freezing. Sometimes insulating the all the way around prevents the warming they would have gotten if they had only been blanketed on one side.
    That being said, it's rare for a pipe in a crawlspace to freeze. The ground under a structure, as long as it's skirted keeps things warmer.
    It's common for pipes above the first floor to freeze in outside walls if the power goes out for a day or two.
    Putting pipes below the frost line also works.
    There is nothing wrong with PEX, and many are switching to it. I wish there had been more PEX run when I was younger. I don't think it's realy healthy to do much soldering.
    May 2013
    New Hampshire
    Thanks Gary...Pex looks a lot easier to install. Rather go that way.
    The building is skirted all around with a maximum distance from ground to siding of about 2 ". Wanted to keep some airflow so it doesn't get too moldy under there. Most of the installers I have been talking to were going to box the pipe and spray foam it. Could I leave a vent from the floor to the box that the pipes are in to help heat it? I will still insulate the walls of the box too.
    If air movement is within reason, it should be okay in the crawl.
    Around here, you would skirt down to the ground, and then add ventilation.
    May 2013
    New Hampshire
    I keep hearing about an element that can be submerged into the pipe to keep it at a constant temperature, but I can not find any info on it. Any idea's what it is and where to look for one? Thanks!
  1. Building a new master shower with antique-looking exposed copper plumbing
    By ceiiinosssttuu in forum Shower & bathtub Forum & Blog
    Last Post: 05-17-2013, 03:57 PM
  2. Building a Laundry Grey Water Seepage Pit - Stage 1: Indoor Plumbing
    By ChakaRaka in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-29-2013, 10:50 AM
  3. Ontario Building Code for Plumbing a bathroom in Mississauga
    By lbgradwell in forum Canadian Plumbing Code Questions
    Last Post: 02-22-2011, 03:36 AM
  4. help with building plumbing guidance
    By zelik in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-08-2009, 02:52 AM
  5. building commission/permit questions
    By yarg28 in forum Remodel Forum & Blog
    Last Post: 10-29-2008, 07:10 PM
