Results 1 to 5 of 5
Thread: Pump pressure issues
    DIY Junior Member Truelight's Avatar
    May 2013
    Missouri
    Default Pump pressure issues
    Facts: low pressure 20 psi. We had water logged
    pressure tank. Changed tank. Water has not gone
    into tank. Still only 20 psi. Did not install check
    valve. We have a submersible pump. If I turn off
    power to pump pressure holds at 20. If I leave
    power on but close the shut off valve after guage,
    pressure stays at 20. Do you have any ideas?
    Should I have put in a check valve? Thanks
    Feb 2011
    NW Ontario, Canada
    A checkvalve won't help. Do you know if there are any checkvalves between the pump and the tank besides the one on the pump? If there are any, they could mask a leak.
    Moderator valveman's Avatar
    Mar 2006
    Make sure the gauge is good!
    May 2013
    Missouri
    Ok so I think I might have a leak between my well pump and house. At the well house I have 2 faucets, 1 on either side of what I think is a check valve. In my basement I have a shut off. My pump runs continually at 20 psi. How can I test to see if there is a leak?
    Mar 2006
    As long as the gauge is good, when the pump is off, if the pressure just stays at 20, you don't have a leak. At least you don't have a leak on this side of the check valve. Sometimes you can have a leak in the little nipple between the pump and the check valve. That leak you won't see until you pull the pump.
  1. Grundfos Constant Pressure System Issues--Fluctuating Pressure
    By Alan Adamson in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-15-2011, 08:56 AM
  2. sears shallow well jet pump mo. 390.25021 pressure switch issues??
    By ray19 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-22-2010, 12:27 PM
  3. Gould 1 HP pump / wellxtrol wx250 with sprinkler pressure issues.
    By AirCactus in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-17-2010, 09:34 PM
  4. Water pressure issues from yard hydrant connected to well pump.
    By majesty8 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-31-2010, 07:18 PM
  5. Pump pressure issues
    By yukonLoki in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-30-2009, 07:11 AM
