Results 1 to 7 of 7
Thread: Gator bite and tub shower problems
    DIY Junior Member weasels2's Avatar
    May 2013
    grove city, ohio
    Default Gator bite and tub shower problems
    Over the weekend, I changed my daughters shower/faucet hardware as we put in a new tub and surround. It was a moen brand and everything went well. I used gator bites and found no leaks, but after completing the job, we turned on the water and found that when set on tub fill, not only did water come out of the tub faucet, it also came out of the shower head. I called moen's help line and was told that if I had used a gator bite-EL on my downspout to the faucet, that was the most likely reason for the problem. Has anyone else had this problem and could there be other reasons for the water coming out of the shower head even though the diverter had not been flipped? Thank you.
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Quote Originally Posted by weasels2 View Post
    Over the weekend, I changed my daughters shower/faucet hardware as we put in a new tub and surround. It was a moen brand and everything went well. I used gator bites and found no leaks, but after completing the job, we turned on the water and found that when set on tub fill, not only did water come out of the tub faucet, it also came out of the shower head. I called moen's help line and was told that if I had used a gator bite-L on my downspout to the faucet, that was the most likely reason for the problem. Has anyone else had this problem and could there be other reasons for the water coming out of the shower head even though the diverter had not been flipped? Thank you.
    What pipe did you use, if its pex then thats the problem as the id restricts the flow and will cause this. I would never use a "gator" or shark bite for the tub sput but I don't see that as being the reason for this.
    If there is "any" restriction on the tub spout piping, it will force water up to the shower head.
    It needs to be unrestricted copper, galvanized or brass.
    CPVC or PEX won't work.
    IF you used PEX, or did not remove the "stiffener" inside the fitting if you used copper, that is the problem. Unless, are you sure you did not put the valve in upside down?
    May 2013
    grove city, ohio
    Thanks to all that responded. I did not remove the "stiffener" and did use 1/2 inch copper. I do know the valve is in the proper position. I am going to remove the gator bite and sweat a 1/2 inch copper elbow and hopefully that will take care of my problem. Thanks again
    ON the Sharkbite, the internal stiffener is designed and intended to be removed if using it on copper...I'm assuming that's true with the Gatorbite fitting as well. The easiest thing would be to remove that and see if it solves the problem, and if not, then solder on a fitting. Now, most pros would never have used the press-on fitting in the first place, but that's a different story.
    quote; remove the gator bite and sweat a 1/2 inch copper elbow
    Why not do it the "easy way" and just remove the stiffeners from both sides?
  1. Shark bite
    By plumberwanabe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-28-2012, 11:41 AM
  2. Thinking of replacing a Goulds Irri-Gator
    By PEW in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-20-2010, 01:23 PM
  3. How tightly should [Gator|Shark]bite fittings be screwed to threaded brass?
    By miamicanes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-12-2009, 10:43 PM
  4. I had to bite my tongue...
    By Gary Swart in forum Toilet Forum discussions
    Last Post: 08-24-2009, 02:52 PM
  5. shark bite
    By perrycat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-25-2007, 09:49 PM
