Results 1 to 3 of 3
Thread: priming 7,ooo ft siphon
    DIY Junior Member firebird's Avatar
    May 2013
    Alaska
    Default priming 7,ooo ft siphon
    Greetings.
    I would like to bring water from a pond 7,000 ft away from a remote work area. The pond is 60 vertical feet above the work area. The terrain is level for the first 6,000 ft from the pond until it drops 60 ft over the last 1,000 ft. I hope to use 1.5 in hdpe pipe with a valve at the lower end and another valve at the 6,000 ft location at the beginning of the elevation change. My hope is that I could use a 2 in honda trash pump to push water through the 1.5 in hdpe to prime the entire length so i will have water on demand using a valve down at the site. I imagine closing the valve at the lower site and opening the valve at the 6,000 ft point until the lower section fills up and water comes out of the upper valve. Then shutting off the pump and leaving the intake in the pond for water on demand. I am wondering if the 2 in trash pump will be able to push the water that far and anything else I might want to consider.
    The pipe will be level so ANY pump can push the water to fill it. You do not need a valve at the upper end, just have the inlet opening under the water's surface once the pipe is full of water. As soon as you open the "outlet" valve water will start to flow. If you want to keep the pump inline, it might cause severe restriction or stop the flow entirely if it is a "diaphragm' pump, rather than a centrifugal one.
    May 2013
    Alaska
    Thank you for the reply. My concern is getting all the air out of the pipe. I think there might be a point at a certain distance from the pump where the water only partially fills the hdpe pipe. As far as the pump being inline, I hope to connect the pump's discharge hose directly to the intake of the hdpe to push the water and when removing it, doing so underwater.
  1. priming help please
    By tooks7 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-24-2012, 04:38 PM
  2. another priming question
    By flagirl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-27-2008, 06:05 PM
  3. Priming problems
    By markb9898 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-01-2007, 07:27 AM
  4. New help priming
    By sebs in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-12-2006, 05:38 AM
  5. Priming problems?
    By ron in sc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-07-2005, 09:28 PM
