Thread: Best way of protecting banisters from harm during demolition
    Jul 2009
    North Vancouver, BC
    Default Best way of protecting banisters (railings) from harm during demolition
    My apprentice came up with a great solution for protecting some banisters during a recent demolition out in UBC. We had to drop the ceiling and walls around a 100 year old staircase and wanted to protect the banisters from harm.
    We used up all our Ram Board the first day and David (my apprentice) asked me if we could use the Ram Jamb instead. I had never thought of that and we tried it out. Worked like a champ.
    Once protected we built a scaffolding and simply sat some plywood over the Ram Jamb. Then the garbage cans. I sent the helper into the attic and he boot stomped the ceiling. We dropped the ceiling in no time!
    Love this stuff!
    We found that we could even cut the stuff with the chop saw and once the scaffolding was removed we improved the outside corner.
    I'll get some pictures up.
    JW
    Jul 2009
    North Vancouver, BC
    Default Setting up for demo over a staircase and banister
    Here is how we set up this rig to protect the railings (banisters) from harm.
    This was a fast set up and it worked so well.
    Jul 2009
    North Vancouver, BC
    Default Cutting Ram Jamb for banister's outside corner
    Once we removed the plywood the outside corner was not protected as well as I would have liked. I thought about cutting the Ram Jamb on the forty five and tried my chop saw. This worked so well. I had a cross cut blade on the saw and it went through the Ram jamb like butter.
    The Ram Jamb can over lap each other so set up was a breeze.
    I might cut the other inside miter next so these pieces can be used for inside or outside corners in the future.
  1. Demolition Advice
    By jdf405 in forum Remodel Forum & Blog
    Last Post: 10-19-2009, 06:51 AM
  2. Do natural products harm toilets?
    By JustCurious in forum Toilet Forum discussions
    Last Post: 02-19-2009, 06:13 AM
  3. Chipping/Demolition hammer recommendations
    By JeffH in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-05-2008, 12:05 PM
  4. Demolition Advice
    By DIYlady in forum Remodel Forum & Blog
    Last Post: 06-14-2005, 06:32 PM
  5. will extreme cold harm toilet?
    By macska in forum Toilet Forum discussions
    Last Post: 05-04-2005, 07:50 PM
