ovidiu
I have an Integrated Grohmix 34-436, which served us well for the past 10 years:
However few weeks ago, the thermostat valve started misbehaving, not letting enough hot water through. So I bought a replacement and installed it.
To test whether it works or not, I put the lever in the open position and turn on the cold and hot water service stops. Unfortunately only hot water comes out, the cold water is not let through. I tried turning the knob on the thermostat valve to no avail, only the hot water keeps coming out, no matter which position the knob is in.
When I put back in the old thermostat valve, the water is mixed correctly, just not as hot as it should.
Is there a calibration procedure that needs to be done on the valve itself? Besides the front knob, there isn't anything else that could be adjusted.
Is there a correct way to insert the cartridge? There is a longitudinal cut on the cartridge, does it need to be in a certain position when I push it in and before I start to screw it in?
Any thoughts on what could be the problem? At this point I'm thinking the replacement thermostat valve is bad.
