Rapid Cycle Well Pump
warrens
quebec
Hi
(NB SUBJECT SHOULD BE RAPID CYCLE NOT RECYCLE!)
I have had constant problems with my well pump (400 feet deep) running dry and then either frying the pump or heating the pipe up so much that it bursts and my well guy comes and pulls it out to replace the piece of pipe.
the main reason I believe this was happening (apart from the fact that I have a very low producing well which means I have to manage water very carefully) was because my wires were the wrong gauge so the pumptech was never shutting the pump off in time to save this.
I believe I have mainly solved this problem since purchasing a cycle sensor valve through suggestions on this site.
That has worked well telling me when the well is dry and shutting off the valve, however I am now having a RAPID CYCLING problem. I have water in the well and if I turn off the RAPID CYCLING reset then the pump works fine. Otherwise it seems to go into recycle when it reaches the cut off pressure.
I have 2 thoughts
1. there is a hole in the pipe as before, however it is still able to pump water up
2. the pressurized water tank has a leak, however it appears to be working fine and has good pressure
any thoughts suggestions welcome
I can bypass the RAPID CYCLE cut off but dont want to fry my pump again
thanks Warren
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Isolate the tank outlet and see if you are losing pressure when the pump shuts off, assuming you don't have a topside checkvalve to mask it.
Are you sure it is recycle and not rapid cycle?
Quoting from http://www.cyclestopvalves.com/prod_sensor_geninfo.html
The "Rapid Cycle" feature of this relay monitors the duration of time the pump is on. If the pump "run time" is shorter than the Cycle Sensor minimum set time, the pump will be shut down before damage from cycling occurs. Length of acceptable minimum pump run time is adjustable and can be set for as little as 0 seconds to as much as 600 seconds. (Rapid cycling can be caused by water logged or improperly sized tanks, improper pressure switch settings, control malfunctions, broken check valves, and chattering contacts.)
warrens
quebec
Thanks LLigetfa
Yes you are correct I should have said rapid cycle. I will have a look re losing pressure when the pump shuts off and get back to you
warrens
quebec
Hi
I checked for losing pressure and it seems ok-it stays at a constant pressure
warrens
quebec
Thanks, can you just guide me as to what exactly in simple terms I have to do to do the drawdown test to evaluate this
thanks
LLigetfa
NW Ontario, Canada
When the pump reaches the shutoff pressure, draw off water from the tank into a pail and measure how many gallons you can draw down until the pump kicks back on. That will tell you how much drawdown you have. If you don't get as much drawdown as you should, then there is probably a leak in the bladder.
For example, a 40 gallon tank should give you 12 gallons of drawdown with a 30/50 pressure setting.
warrens
quebec
Thanks again LLigetfa,
I have done the drawdown test and it seems fine I get about 8 gallons on a 20 gallon tank at 20/40 pressure setting. I also tested the pressure of the tank empty and at the cut off and cut in and it all seems ok-One thing though.. when it gets close to the cut off, i do hear sounds from the tank, that to me sound like a bladder releasing from something, itself or the side.
I dont know whether it always has this sound but I just assumed that it acts like a balloon and when it gets to the higher pressure there shouldnt be any notable sounds of the bladder moving?
LLigetfa
NW Ontario, Canada
Is the pressure switch on the tank Tee or otherwise close to the tank? Does the pump start and stop normally through the pressure range? Have you timed the cycles to see how long the pump runs and how long it stops? What time is the rapid cycle set to?
If the cycles are short and frequent, you might want to consider a larger tank or a CycleStopValve.
Valveman
Cary Austin
cyclestopvalves.com
If you didn’t adjust the Rapid Cycle function of the Cycle Sensor, it is set at 30 seconds. If you are not getting at least 30 seconds of run time, something is wrong. Your pressure switch maybe too far from the tank, or you could have a faulty check valve. Rapid cycling and pumping the well dry are two of the worst things you can do to the pump. The Cycle Sensor will catch both of those things, but you need to solve the problem or the Cycle Sensor will keep tripping.
warrens
quebec
Hi
My switch is close to the tank and the sensor was set at about 80, I have reduced it to 10 and it seemes to have stopped the rapid cycle error. I have tried at 40 and it still occurs but at 30 it seems ok so far
the pump pumps for more than 30 seconds ( acouple of minutes maybe-. it seems to trip out when the pressure switch cut off activates.
warrens
quebec
thanks for your perseverance guys
LLigetfa-I am pretty sure I don't have a check valve and haven't noticed water hammer anywhere
Valveman- Double bouncing? Is that simply looking at the contacts and seeing if they release and then reattach quickly?
warrens
quebec
thanks
i will hunt for a check valve then-I guess it could be down the well?
Valveman
Cary Austin
cyclestopvalves.com
The Check Valve is usually on the pump itself. Also check to make sure you don't have too much air pressure in the tank. The tank bladder hitting the bottom can also cause the switch to bounce.
warrens
quebec
Do you both agree therefore, that I probably don't have a hole in the pipe somewhere down the well-which is the issue I seemed to get often before I replaced the pumptech?
Valveman
Cary Austin
cyclestopvalves.com
I have water in the well and if I turn off the RAPID CYCLING reset then the pump works fine. Otherwise it seems to go into rcyc when it reaches the cut off pressure.
The Cycle Sensor is supposed to go into RCYC when the pump shuts off, if the pump run time was not as long as the Rapid Cycle setting of the Cycle Sensor. In other words, if the Rapid Cycle feature is set for 30, the pump must run for at least 31 seconds before the presure switch shuts it off, or the Cycle Sensor will go into RCYC fault and not let the pump come back on.
LLigetfa
NW Ontario, Canada
If you have a sticky checkvalve, you should notice some water hammer when the pump shuts off. Basically what happens is water starts to rush back to the well for a moment before the checkvalve slams shut. It also causes the needle on the pressure gauge to bounce. Take off the cover from the pressure switch and watch the contacts to see if there is bounce there. Could simply be a bad switch.
