Results 1 to 5 of 5
Thread: Installing a toilet flange
    Default Installing a toilet flange
    I am getting ready to place ceramic tile in my bathroom. Does the toilet flange sit on top of the tile or does it sit on the conc. board? If it sits on top of the tile does it have screwed into the tile?
    Thanks Much!!
    Plumber plumber1's Avatar
    Aug 2005
    Florida
    Unless it's cast iron it should be screwed down and sit on top of the tile...
    You will have to drill holes through the tile so the screws and go into the subfloor. I like stainless steel for this as they last much longer than others. Drill the holes with a slightly larger diameter than the screw to prevent breaking the tile when you sink the screws.
    You can also put notches in the tile to line up with the holes in the flange so that you only need to go through the cbu and the subflooring when you screw it down. Much easier cutting those notches with the wetsaw than drilling if you are using something like a hard porcelain tile (unless you have access to diamond bits).
    Default kwhitt1017
    Thanks all for your responses
