Thread: Toro 53709 valve won't close
    DIY Junior Member donl1150's Avatar
    Mar 2013
    MN
    Default Toro 53709 valve won't close
    Trying to get yet the system fired up for the year. Got all zones working except one. Replaced the solenoid and it still won't shut properly. Have not unscrewed to get to the diaphragm but is that the likely cause it won't shut off? Some debris stuck in there perhaps? Other possibilities?
    Mar 2011
    Long Island, NY
    Quote Originally Posted by donl1150 View Post
    Did you replace JUST the solenoid itself, or the whole valve? My limited experience has taught me that these valves have to have thier solenoids screwed into them at the correct depth, or they will not properly seat the pilot (solenoid plunger) seal and this will cause the diaphragm seal to not seat. Using the wrong solenoid, plunger, or incorrect spacer, itf any can do this too.
    Or, the diaphragm may have a crack or dirt like you said in its seat area. Just get a rebuild kit or a new valve assembly to have on hand in case you need anything additional as they are cheap enough. I think the whole assembly costs just a little more than the repair parts
    Mar 2013
    MN
    Well, I took the valve body apart, cleaned it up and tried again. Still won't shut off. I did just replace the solenoid only. I then took it apart again and this time discovered a tiny pebble, about 1/16" in diameter. Got that out and now it shuts off except one small 1/4 round fixed spray head is still leaking ever so slightly. The remaining 180 degree heads all shut off.
    I wonder if the diaphragm was damaged by the pebble and just enough water is getting by to open that fixed spray head but not enough pressure to open the bigger heads?
    Are there any good websites to get the repair parts for these valves? The big box stores don't carry repair parts.
    Don
    Mar 2011
    Long Island, NY
    Don
    Don, Goog;le is your friend; use it: http://www.sprinklerwarehouse.com/To...rts-s/7343.htm.
    http://www.toro.com/sprinklers/valves/inline/53709.html
    I've bought lots of irrigation stuff from them and they are a good vendor, although I am sure their are plenty others out there
  1. Toro Jar Top Solenoid Valve Installation
    By k11 in forum Irrigation / Sprinkler Forum
    Last Post: 08-24-2011, 03:32 AM
  2. Sprinkler valve doesn't appear to close
    By Rshane in forum Irrigation / Sprinkler Forum
    Last Post: 09-10-2009, 01:20 PM
  3. Valve will not close
    By denver.home in forum Irrigation / Sprinkler Forum
    Last Post: 05-20-2007, 07:12 PM
  4. Toro valve help
    By Tom Keiser in forum Irrigation / Sprinkler Forum
    Last Post: 07-07-2006, 09:23 AM
  5. shower valve hard to close
    By kjinpb in forum Shower & bathtub Forum & Blog
    Last Post: 06-04-2006, 08:04 PM
