Thread: The ~button~ in a diverter valve
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default The ~button~ in a diverter valve
    Is it good practice when the ~button~ / plunger in a diverter valve get's sticky - to remove it off the valve body and just add some sort of grease...
    Mineral deposits may need to be cleaned off. Silicon based plumber's grease helps keep a CLEAN one working well longer. But, some of them end up being pitted, and then they don't work well unless replaced.
    Usually, by the time it gets like that, it is worn to the point where it should be replaced. You have to remove it to "grease it" anyway.
  1. Moen push button diverter plug
    By badreligion9265 in forum Shower & bathtub Forum & Blog
    Last Post: 12-06-2009, 10:35 PM
  2. Push Button Diverter
    By stormyv77 in forum Shower & bathtub Forum & Blog
    Last Post: 09-17-2009, 08:06 AM
  3. Push Button Diverter stuck on Kohler K-305
    By jbanks100 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2007, 06:39 AM
  4. delta push button diverter streams water
    By ironmandan in forum Shower & bathtub Forum & Blog
    Last Post: 09-30-2005, 08:09 PM
  5. Push-button diverter
    By DavidG in forum Shower & bathtub Forum & Blog
    Last Post: 01-13-2005, 03:12 AM
