Results 1 to 5 of 5
Thread: Deck Mount Tubs not Meant for Showering ?
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default Deck Mount Tubs not Meant for Showering ?
    TL made a comment and I just to re-explore it as a thread..
    Are Deck Mount Tubs not meant for shower/shower enclosures
    Or is it just the premise that is is more liable/suspect to water intrusion just due to the the layout of a deck mount top.
    For MY application, I was thinking I would use a deck mount tub, incorporate deck mount controls for tub filler/tub control on the deck and it would still be built with 3 sided wall - 2 sides with tile right ontop of the edge of the tub.
    DIY Senior Member DougB's Avatar
    Jun 2010
    Minneapolis - Land of 10,000 taxes
    You can get drop-in tubs that have a tiling flange on three sides. The outside rests on deck wall you build and tile - but water doesn't get on that outside lip - because of the shower door or shower curtain.
    You need a tile flange. What's done is to shim the studs above the tub (say 1/4") this allows the cement board to come down over the flange. You caulk this space with 100% silicone.
    If a hammer won't fix it, it's an electrical problem.
    Feb 2011
    NW Ontario, Canada
    You could use a round shower curtain same as what you'd use on a clawfoot tub.
    Jun 2006
    Tile Flange aside - I was planning to make my own flashing----that would be waterproof to the stud down to the tub edge. Rock ontop and 2 more layers of waterproofing layers (paintable) + then the space is sealed between the tub and the cementboard...
    Use an approved method to make the seal. It's much easier to get a tub with the tiling flange built in, but most manufacturers sell an add-on one for their tubs. The hassle is, with any add-on one, it is up to the workmanship as to whether it will work or not...a factory tiling flange will work. Kerdi can be used - Schluter has a diagram on their recommended method to install it on their website when using this. I'd have second thoughts about using any paint-on waterproofing on a drop-in unless there was a tiling flange.
  1. Adapting deck-mount tub faucet to wall-mount
    By adrury in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-09-2013, 06:23 AM
  2. Wall mount tub filler with deck mount controls
    By islandgrl in forum Shower & bathtub Forum & Blog
    Last Post: 05-15-2012, 06:17 AM
  3. Deck Mount Tub Faucet
    By newmex999 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-10-2010, 06:43 AM
  4. setting deck height for deck mount tub fixture
    By jasperx in forum Shower & bathtub Forum & Blog
    Last Post: 09-07-2008, 07:56 AM
  5. minimal deck mount mixer
    By etowns in forum Shower & bathtub Forum & Blog
    Last Post: 05-19-2006, 03:16 PM
