Results 1 to 5 of 5
Thread: How small can my service neutral be when most of the load is 240v?
    Default How small can my service neutral be when most of the load is 240v?
    Non-residential 120/240 single phase service. 320amp meter to (2) 200 amp panels. The distance from the meter on a pole to service panels are 50ft. I'm running 3/0 copper for the phase conductors. #6 for the grounds.
    First panel will have 160 amp continuous load. Everything connected will be 240v. The second panel will have 40 amps of 120v and 120 amps of 240v.
    Even though there is no 120v equipment on the first panel, I can't go lower than the GEC, right? #6?
    Jun 2007
    North Carolina
    DIY Junior Member Glennsparky's Avatar
    Oct 2012
    Oviedo, FL near Orlando
    Quote Originally Posted by tkeoki View Post
    ...Even though there is no 120v equipment on the first panel, I can't go lower than the GEC, right? #6?
    Or no neutral. There's no code forcing you to bring a neutral to a box. But, then you could never use that box for a 120v load.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    I thought 3/0 copper service required #4 GEC. I'm probably reading the wrong table again, though...
    Jun 2007
    North Carolina
    Quote Originally Posted by bluebinky View Post
    You are correct about a #4
  1. Replies: 2
    Last Post: 11-28-2011, 03:29 PM
  2. Replies: 2
    Last Post: 03-23-2011, 06:34 AM
  3. 240v 60amp service
    By John07 in forum Electrical Forum discussion & Blog
    Last Post: 01-30-2011, 09:51 AM
  4. service riser needs for an electrical service upgrade?
    By myladyfae in forum Electrical Forum discussion & Blog
    Last Post: 02-22-2010, 11:28 AM
  5. 1/2" service line too small?
    By kurtk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-25-2005, 02:05 PM
