Results 1 to 7 of 7
Thread: 16 Gauge Wire in Circuit?
    DIY Junior Member achaean27's Avatar
    May 2013
    Chicago
    Default 16 Gauge Wire in Circuit?
    I have a setup where I need to connect a pump (ac motor) to a relay switch that is hard wired to a 15 amp electrical circuit (14 gauge wire). The maximum wire size to connect the pump motor is 16 gauge. Below would be the setup:
    15 amp breaker @ 14 gauge wire --> Relay --> Pump
    The amp draw of the pump is no more than 3 amps. Most of the time it would be 1.5 amps.
    My question is, can I connect a 16 gauge wire from the relay to the pump? Is there a better way to wire this?
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    "The maximum wire size to connect the pump motor is 16 gauge"
    If the pump comes from the manufacturer with 16 ga, you can wire that to the relay. But you cannot use any 16 ga anywhere else in your rig, it all must be 14 ga.
    Why is the maximum to the pump 16 ga? Why can it not be 14 ga?
    Jan 2012
    Los Angeles, CA USA
    Default How to determine which wires are in a three wire circuit when six wires are in a....
    Sorry, wrong place.
    May 2013
    Chicago
    Quote Originally Posted by Homeownerinburb View Post
    I'm not sure why the motor is 16 ga, but that's what the technician says. Thank you for the advice, I'll give it a try just to the relay.
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by achaean27 View Post
    The manufacturer is not bound by the code the way we are.
    The cords on the various things you plug into a 20 amp general purpose circuit are not 12 ga, are they? They are large enough for the item being plugged in.
    Look inside a dish washer some time. Not much 12 ga in there.
    There is seldom a "maximum" wire size for anything, unless you try to use a wire that exceeds the capacity of the connectors.
    The manufacturer of the device knows the internal load and needs of what's inside and then, it is tested for proper operation so knowing what they know, they can and often do use smaller wires than the circuit that may feed it. Up to the device, the wire must be sized based on the protection device (the fuse or CB)...after that, in the device, anything goes once it has passed testing. This is why you can plug in a lamp with a 50W (less than 0.5A) load into say a 20A branch circuit.
  1. advice on wire gauge for built in oven
    By jono604 in forum Electrical Forum discussion & Blog
    Last Post: 12-15-2011, 11:23 AM
  2. Wire gauge for new double-oven?
    By Artie in forum Electrical Forum discussion & Blog
    Last Post: 11-11-2010, 07:51 AM
  3. wire gauge change mid circuit
    By rockycmt in forum Electrical Forum discussion & Blog
    Last Post: 01-09-2009, 11:29 AM
  4. breaker size for 12 gauge wire
    By whoazone in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2008, 05:02 PM
  5. heavy gauge bare copper wire
    By solutions in forum Electrical Forum discussion & Blog
    Last Post: 03-26-2008, 07:11 AM
