Results 1 to 6 of 6
Thread: Installing a Tankless Water Heater, with Video
    Default Installing a Tankless Water Heater, with Video
    Here is a nice video of Tankless Guy's installation of a Navien Tankless Water Heater.
    Scotsman mcconnellplumbing's Avatar
    Dec 2010
    Wellston, OK
    The A in 240 A designates a circulating system with buffer tank. I didn't see the circulation loop return line installed or tied in at the bottom of the unit, the condensate drain line installed, or the temp and pres. relief valve drain installed. In the attic I would question the rigid plastic water filter and cannister unless in a warm climate. Code requirements here do not allow the condensate drain to tie into the T & P drain line. They also require a pan and pan drain under the tankless water heater.
    Dec 2010
    Wellston, OK
    One other note, by using the 3/4" Vanpex fittings, you are effectively reducing the inside diameter of the water line to 1/2" at each fitting. The unit has 3/4" inlets and the reduced inside diameter fittings will reduce the potential volume of water flow through the unit. We use 3/4" hard copper, type L or use 3/4" Wirsbo/Aquapex fittings and tubing. Good to see a real 3/4" ID gas supply line. A lot of plumbers use a 5/8" ID flex gas supply and it will limit the gas flow and throw the unit into an error code when running high.
    DIY Junior Member markstoppard's Avatar
    Sep 2011
    Indianapolis, Indiana USA
    Very nice...thanks for posting! This should help me get started
    This video is very helpful. I actually sent it to a couple friends of mine who are on the fence about switching to tankless.
    Tankless Water Heater Reviews - Switch to tankless today and be amazed at the savings on your energy bills
  1. Tankless Water Heater for Tub
    By BlackNoir in forum Tankless Water Heater Forum
    Last Post: 03-27-2009, 03:31 PM
  2. tankless water heater
    By pman in forum Tankless Water Heater Forum
    Last Post: 05-14-2008, 11:50 AM
  3. tankless water heater
    By pman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  4. installing tankless with recirculating hot water
    By billhayton in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-30-2008, 09:02 PM
  5. tankless water heater
    By meckroth in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-23-2006, 04:42 PM
