Results 1 to 2 of 2
Thread: Leak at check valve on my well.
    DIY Junior Member JasonH's Avatar
    May 2013
    Florida
    Default Leak at check valve on my well.
    I have a leak at the fitting on my check valve by my well. Should I replace the entire check valve, or is it possible to repair this another way?
    Name:  check valve 01.jpg
    Here you can see the leak when it's pumping:
    Name:  check valve 02.jpg
    Aug 2009
    South*East
    To repair the leak will require removing the check valve. At that point I would replace the check valve along with the two males.
    John
  1. a separate flow check valve or a circulator with a flow check valve?
    By diyfun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-08-2012, 08:31 PM
  2. Swing Check vs. dual check vs. double check valve
    By colbymom in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-10-2011, 01:19 PM
  3. Combo ball valve/check valve for ejector pump...
    By hhcibtpaun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-17-2009, 12:27 PM
  4. Detail question relating to sewage pit check valve and shut off valve.
    By Longwood in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-27-2007, 05:17 PM
  5. Leak Check
    By smakcaine in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-16-2006, 06:52 AM
