Vanity P-Trap weird configure
rosem637
Michigan
SHould the vanity drain look more like the setup for the laundry?
I think I would just have to lengthen the tailpiece and attach a 45 to the stub out to be able to match the wall bend to the p-trap.
My preference would be for the one on the left, however both that are pictured are legal.
Sometimes in a handicap bath, they will offset below the sink or lav to keep the trap closer to the wall for knee room.
Your biggest problem with the one on the right might be keeping everything together when people start putting bottles and boxes into the cabinet and bump the drain line. And it WILL "foul up" and create odors because of the long distance ahead of the trap.
rosem637
Michigan
Also there are what appears two slip-joint nuts I believe are missing. One on the horizontal piece between the 2-90s and one on the piece that goes into the trap adaptor. How can two compression nuts be missing but no leaks?
