Thread: Vanity P-Trap weird configure
    DIY Member rosem637's Avatar
    Jan 2013
    Michigan
    Default Vanity P-Trap weird configure
    SHould the vanity drain look more like the setup for the laundry?
    I think I would just have to lengthen the tailpiece and attach a 45 to the stub out to be able to match the wall bend to the p-trap.
    My preference would be for the one on the left, however both that are pictured are legal.
    Sometimes in a handicap bath, they will offset below the sink or lav to keep the trap closer to the wall for knee room.
    Your biggest problem with the one on the right might be keeping everything together when people start putting bottles and boxes into the cabinet and bump the drain line. And it WILL "foul up" and create odors because of the long distance ahead of the trap.
    Jan 2013
    Michigan
    Also there are what appears two slip-joint nuts I believe are missing. One on the horizontal piece between the 2-90s and one on the piece that goes into the trap adaptor. How can two compression nuts be missing but no leaks?
  1. Bathroom vanity p trap
    By butwhydoitalk2u in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-24-2012, 06:32 AM
  2. P-trap in bathroom vanity
    By Mikes97gts in forum Shower & bathtub Forum & Blog
    Last Post: 03-20-2011, 07:48 AM
  3. Will this work for new P-trap for vanity?
    By skibumdc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-30-2009, 10:19 AM
  4. How to configure a drip zone? (control/timing)
    By blown in forum Irrigation / Sprinkler Forum
    Last Post: 08-07-2008, 07:42 PM
  5. Vanity sink trap - can I use 90's after the trap?
    By chassis in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-16-2006, 06:40 PM
