Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Thread: Is installation too flimsy?
  1. #16
    DIY Junior Member Harper's Avatar
    May 2013
    Santa Clarita
    For irrigation, you will need a back flow device to be legal. You can't legally hook up irrigation without protection to the water supply. It's a safety hazard for you and you neighbors.
    Thanks! I think I'm fine with the sprinklers. I'll look for the one for the spigot.
    My last concern I think is how to reinforce the entire structure so that we don't eventually compromise the pipe and wall from the hose pulling against it. Any ideas? Something to mount on the wall? Screw into the patio?
  2. #17
    Jan 2008
    If you insist on keeping the existing set-up, set a post in the concrete to act as a support for the piping. I would also set a second post to protect the PVC going into the ground, because that will be a likely spot for it to get broken off.
  3. #18
    DIY Senior Member asktom's Avatar
    Nov 2009
    Victor, MT
    I agree with Cacher but would also paint the PVC to protect it from sunlight, which can make the PVC brittle.
  4. #19
    Yakima WA
    There are state and federal laws pertaining to BFPs. I would find it hard to believe that California, with the most restrictive environmental protective laws in the US, don't have requirements for BF devices and provisions for periodic inspections to make certain they are not only installed, but are functioning properly. I have to suspect the qualifications of the "plumber" that did this work for you.
  5. #20
    There's a difference between BFP and a vacuum breaker, and you may be required to have both, but they are not interchangeable!
  6. #21
    DIY Junior Member ritzplumbing's Avatar
    May 2013
    los angeles
    Lots of good advise here. I called Ritz Plumbing, the 24 hour emergency plumber in Rancho Park, when I needed help installing my irrigation system.
  1. Replies: 97
    Last Post: 02-22-2013, 09:55 AM
  2. PRV Installation Necessary???
    By lam1303 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-04-2009, 11:08 AM
  3. Tub Installation
    By boomer70 in forum Shower & bathtub Forum & Blog
    Last Post: 06-22-2007, 08:04 PM
  4. tub installation
    By sumballo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-06-2005, 04:52 PM
  5. how to 'ground' a gelcoat tub's flimsy quality? also, vikrell question.
    By kavita in forum Shower & bathtub Forum & Blog
    Last Post: 12-15-2004, 05:08 AM
