Results 1 to 8 of 8
Thread: What's the secret sauce on manuerving a Drop in Cast Iron Tub
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default What's the secret sauce on manuerving a Drop in Cast Iron Tub
    Cast Iron Standalone or Apron Tub. No Problem. Just shimmy and set it it's place...with tons of help.
    How about a 60" Cast Iron Drop In - with a working width of 60".....
    I do prefer the cast iron, as the missus likes the soak.
    Just wondering any tips on how to get a 300 pounder up and over when you only really have leverage on the front and some wiggle room
    with now walls nailed up, and you have your *hands* on the framing..
    Jun 2006
    BTW, one more detail. Went tub shopping today...
    Unless all the floor models were installed to a certain spec, are tubs about 2" higher these days compared to previous yester-years models.
    The Kohler Villager is 60x30x14
    Once it's in a bathroom I can set it by myself.
    http://www.terrylove.com/forums/show...-Cast-Iron-Tub
    Jun 2006
    Heh. I remember that thread. Dropping and CI right on the floor is much much easier than.... figuring out how to life the beast for a drop in, with no room in the back and just *open wall* for hands on the other 2 sides. Might have to play around, cleat it from the drain and do some McGuyvering winching it up and over
    A 60" "drop in tub" in a 60" recess is a disaster waiting to happen, even if you install the "optional tile bead". You put the "cleats" on the back 3 sides, then slide it in, before finishing the front "wall".
    Jun 2006
    OMG. I was thinking about the *box* and did not think about just the 3 cleats as the platform and then deal with the front from there.
    RO - etc to be built. So I should be good on that...
    HJ. A lifesaver. I suppose that CI is not entirely ruled out for the tub replacement versus acrylic.
    I skipped the part about this being a drop in tub. If you are tiling down to it, like putting it within three walls, you may have problems with water.
    Drop-Ins normally aren't for showering.
    Jun 2006
    Any reason on not for showering - if Given the Premise that the construction of the walls to the tub will be waterproofed correctly.
    I have to dig some tech sheets. Was looking at a couple different tubs - have yet to decided on one.
    One was a drop it with a tile flange. I believe I was just going to choose the non flanged as was planning to make my own *flashing*
  1. Galvanized drop pipe causing iron issues?
    By TJanak in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-24-2009, 08:18 AM
  2. cast iron fitting installed in cast iron soil pipe
    By web_surfer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-10-2009, 06:20 AM
  3. cast iron to pvc
    By milkman1969 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-01-2009, 05:30 PM
  4. What's the secret to no leak the first time?
    By TSPORT in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-11-2007, 04:23 PM
  5. I need your secret :)
    By v1rtu0s1ty in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-21-2006, 01:39 PM
