Results 1 to 6 of 6
Thread: IPS / NPT Angle Stops - Outdated Practice
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default IPS / NPT Angle Stops - Outdated Practice
    Is using nipples/FPT ~outdated~ in use/design/practice.
    It's been awhile since I've done a major renov, but for any project with *exposed* plumbing, I generally use Chrome Nipples, with Chrome FPT angle stops.
    For this application, it's a bathroom.
    I am also planning to incorporate a tile-over access panel, somewhere withing the bathroom where I'll be putting stop valves for the water feeds to the bathroom.
    I suppose it's a personal aesthetic decision, as the 5/8 will expose some copper, depending on how close you *cut it*.
    IF you cut it "close enough" there will be no copper exposed, but few installer, or customers, get anal about it. Unless you like crawling around under a sink to see how the supply valves are connected.
    Nov 2009
    Victor, MT
    I like to use brass nipples, but not chrome. I use a length that leaves the stop close to the chrome flange. Like HJ says, unless you crawl under and nose around you never see the brass.
    Jun 2006
    Similar Concept Tom. My POV is that if the stop is chrome, the *exposed piece* from a aesthetics should be all the same finish Hence, I use chrome nipples. They come in all different lengths and depending on RO, I generally aim to have about 2 inches of nipple between the flange and the bottom of the valve.
    I do like exploring the idea of using compression stops but I still prefer the *look* of a particular supple stop.
    Nov 2009
    Victor, MT
    I go for about 1/8" between the valve and flange. I prefer threaded stops because, having done mostly repair plumbing, I have noticed there is much less chance of problems when changing threaded stops.
    +1 on everything asktom says.
  1. needs help in replacing angle stops
    By reyn in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-08-2012, 07:49 AM
  2. Reliable Angle Stops
    By glnow in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-12-2011, 11:43 AM
  3. Ball Valves, Angle Stops & those pesky deee-ziner angle stops
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-10-2011, 06:31 PM
  4. Compression Angle Stops vs. Solder Stops
    Last Post: 04-28-2010, 07:11 PM
  5. Help with angle stops under my sink
    By bluetone78 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-31-2009, 04:25 PM
