Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Double sink rough in. . .
    DIY Junior Member TL's Avatar
    May 2013
    Delaware
    Default Double sink rough in. . .
    Hello.
    Does anyone see any drain or venting issues with this rough in for a double sink? (All 1.5 inch pvc). The vertical vent tees into the shower vent in the attic and exits through the existing roof vent. I will be putting a 2x3 wall there, btw. Thanks!
    Tom
    You should have a 2x1.5x1.5x1.5 fixture cross there, not a 1.5" sancross.
    Snaking that will be hard. They tend to skip over into the other arm.
    The two 90 els above the cross should have been at 42", or if not that, at least two 45's which is considered a vertical installation.
    When I have 1.5 coming from below, I do something like this.
    When I have 1-1/2" pipe, I do something like this.
    And this if I have 2" on the lower side.
    May 2013
    Delaware
    Ahhhh. . .thanks, Terry. That makes sense, but I have one problem . . .
    If I were to run it as you have pictured, I have a problem at the ceiling. As you can see from the attached pic, the vertical pipe "to the drain" lands on the plate above. To the left of the plate in the ceiling joists is a 2x8 on a flat, so I'd rather not drill through that. Above the small nail to the right in the pic is electrical wiring. So, I have to enter the attic through that hole you see there. Is is acceptable to come off with a 45 wye to get there? Please see my crude edit to your pic! Thanks again and I eagerly await your reply.
    TomName:  MasterBath 042copy.jpg
Size:  43.5 KBName:  single_to_double_lav edit.JPG
    There are probably DOZENS of ways the two lines can be connected together. Terry's version is not "chiseled in stone".
    May 2013
    Delaware
    Hi HJ.
    I'm open to suggestions! I want to get this thing done!
    Tom
    May 2013
    Delaware
    This should do the trick, no?
    Name:  MasteBath 043copy.jpg
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Yes, that will do the trick.
    Overkill, but it will work.
    May 2013
    Delaware
    Well it only took 15 minutes, so it was easy enough. Thanks, all, for the replies! Much appreciated.
    That looks pretty dope!
    An expression that my son Jamie uses.
    DIY Junior Member darren_t_johnson's Avatar
    Apr 2013
    Ottawa, Ontario, Canada
    hj, why do you say its overkill? Because both vents run all the way to the ceiling instead of 42" (or 6" above the fixtures)? I'm probably mixing multiple plumbing standards...
    I'm just curious to hear other peoples opinions.
    Nov 2008
    Chicago, IL
    I would of added a clean out above each tee.
    May 2013
    Delaware
    Thanks, Terry.
    Off to the next question. . .
    Aug 2007
    Cincinnati OH
    Quote Originally Posted by SewerRatz View Post
    And accsess how?
    May 2013
    Delaware
    Quote Originally Posted by cwhyu2 View Post
    And accsess how?
    That would be my question also.
    And I'm guessing overkill in the sense that I could save 2 feet or so of pipe by tying in that left drain vent connection at 42" or so instead of at the top. I could still do that as they are just dry fitted at this point.
    Tom
  1. Yet another Single Sink to Double Sink Vanity
    By asdf in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-29-2012, 09:52 AM
  2. Converting to double sink-drain pipe too close to stud for double fixture fitting.
    By Finch85 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-11-2012, 06:04 PM
  3. Double Sink double dishwasher garbage disposal dilemma
    By Pettytalk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-12-2012, 05:04 AM
  4. double sink versus single sink
    By jaydub2010 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-13-2010, 05:04 PM
  5. Converting Double sink vanity to single sink
    By karenwondergem in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-31-2006, 06:17 AM
