Thread: PRV for irrigation system?
    DIY Junior Member snakes's Avatar
    May 2013
    California
    Default PRV for irrigation system?
    I installed a Watts N45B pressure regulator (vertically) on a home mainline not long ago.
    Would the N45B series be a good fit for an irrigation mainline being converted to drip irrigation? It would be installed horizontally in an underground valve box in advance of several irrigation valve clusters. The PSI in the irrigation main is typically 90-100 PSI where I intend to install it.
    If not the Watts N45B series, can you recommend something else?
    It should have adequate capacity, unless the zones have a high volume demand. The PRV does NOT eliminate the requirement for an approved vacuum breaker/back flow prevention device, however.
    Feb 2011
    NW Ontario, Canada
    The specs say the pressure range is 25 to 75 PSI and I think most drip systems should be run below 25 PSI.
    I use soaker hoses with 25 PSI regulators and at that pressure they still squirt and spray, wetting walkways and staining my white siding.
  1. Need design system for Irrigation
    By DGM_Jakarta in forum Irrigation / Sprinkler Forum
    Last Post: 12-05-2008, 04:37 AM
  2. Irrigation System Question
    By pumpkin30 in forum Irrigation / Sprinkler Forum
    Last Post: 08-16-2008, 05:01 PM
  3. Aerator and Irrigation system
    By sburd1026 in forum Irrigation / Sprinkler Forum
    Last Post: 05-27-2008, 10:46 AM
  4. well and irrigation system gone bad, need help!
    By Tedz241 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-10-2006, 11:16 AM
  5. Irrigation on house system
    By gahlen in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-22-2005, 06:15 PM
