Results 1 to 11 of 11
Thread: American Standard Bridge Kitchen Faucet
    DIY Member Geo422's Avatar
    Feb 2012
    Cin oh
    Default American Standard Bridge Kitchen Faucet
    I have the above faucet and it is leaking from the sprayer when the water is on also when the sprayer is in use the water still comes out of the spout.I have replace both valve cartridge.Oring and the diverter .now the sprayer is still leaking when the water is turn on and basic everthing the same .the model number is 4233 721 002 this is about ten years old. Than ks agin to this forum for the past help..George
    The sprayer has its own "thumb valve" so if it is leaking that valve is bad and you need a new spray head. If the water comes out of the spout while using the sprayer, then the diverter is bad.
    Feb 2012
    Cin oh
    Thanks HJ the diverter is new also but could of got a bad one. George
    IF the leak is at the Sprayer, then it is NOT a diverter problem.
    Feb 2012
    Cin oh
    When I turn the water on the sprayer head drips pretty fast. When I use the sprayer the water keeps coming out of the spout and sprayer.
    Problem #1 is a bad sprayer head. #2 is a bad diverter.
    Feb 2012
    Cin oh
    I called American Standard since the faucet is still under lifetime warranty and they say that the sprayer is bad and will send out a new one and another diverter .They did send out last week a diverter and 2 valve cartridges.but the new diverter didnt help. Anyway the people at American Standard was very nice and had no trouble with then. see what happensd when the new sprayer comes in and another diverter.thanks George
    Feb 2012
    Cin oh
    I got the diverter today and put it in.It was the same as the old diverter but it didnt solve the problem of the water coming out of the spout when my wife was useing the sprayer.It just screwed on the stem under the main spout.Am I missing something here?Or not doing something right?
    It should have taken care of the problem, but if it did not, then it was either installed wrong, which would be hard to do normally, or it is a bad design and will never operate properly.l When you say "under the spout", do you mean "inside the spout"?
    Feb 2012
    Cin oh
    Yes inside the spout .I unscrew the spout and saw the same part that American Standard sent me right on top of the stem I unscrew it and the new part screw right back on.then I replace the spout.And yes I keep asking myself did I mess up It seems so simple unscrew on and screw the new one back. Thanks HJ
    Feb 2012
    Cin oh
    Today American Standard sent me the new sprayer head and hose and after installed it the problem is fixed. everthing works like new .thanks
  1. American Standard kitchen faucet fixing
    By Mazcar in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-29-2013, 02:29 AM
  2. New American Standard faucet leaking
    By Mastiff in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-15-2013, 06:06 AM
  3. Leak from base of American Standard faucet
    By Jimmy P in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-30-2009, 12:25 PM
  4. American Standard Bathroom Faucet
    By bakechad in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-11-2009, 05:50 AM
  5. Trying to match an old American Standard lav faucet.
    By SouthPaw in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-22-2005, 06:38 PM
