Thread: Need help with DIY newbee Utility Sink Install
    DIY Junior Member bg18461's Avatar
    May 2013
    Florida
    Default Need help with DIY newbee Utility Sink Install (Pics Inside)
    My first post, please be easy with me...
    Some Background:
    Year house built: 2006
    State/County: Florida/Pasco
    Experience: I'm pretty handy when it comes to fixing/building things around the house, but have really never done any drastic plumbing work besides fixing a leaky drain here or there and installing a pre-plumbed garbage disposal.
    We would like to install a utility sink in our laundry room. First, a few pictures:
    The Laundry Room - I would either install the sink to the right or left of the washer
    Reverse angle of Laundry Room
    Pic of water supply and drain opening left by homebuilder (Pulte)
    Closeup of drain
    Do you think this is something a DIY'er could tackle successfully, or would it be best to call in a pro? If I could tackle any suggestions on connections/installation materials? Thanks in advanced.
    Also, if I go the pro route, any ideas on what kind of quotes I should expect, assuming they just pre-plumb it for me to actually install the sink?
    DIY Junior Member essjay's Avatar
    Nov 2012
    Pennsylvania
    Full disclosure: I AM NOT A PRO and never will be.
    However, I am also a DIYer. As long as your willing to learn and do it right this could be accomplished by someone with reasonable skill, intelligence. and patience.
    There are quite a few gotchas to be aware of however. The PVC fittings you will eventually use must be for the purpose for which they are intended, sink venting must be considered, drain line sizing must be proper, and heights must be followed for traps and drains. If your water lines are copper or pex these will need be run and connected too. Drywall work will be mandatory, so think along those lines also.
    If you considered using the existing cleanout (plugged) as the utility sink drain input you have some reading to do.
    Before calling in a 'pro' I would educate myself as to what is really required and then get some quotes from a few. Then, if they lead you astray I would look elsewhere. It may work, but it wont be right (or to code).
    If you decide to take this on, just know where your going before you start. And ask questions, both here and elsewhere.
    T
    Oct 2011
    You will need to most likely get into that wall:
    The photo below is from the following thread on this site:
    http://www.terrylove.com/forums/show...ice&highlight=
  1. Another Utility Sink Install
    By TheDudeJoe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-18-2013, 08:21 AM
  2. Install Utility sink in laundry room
    By ncinqueg in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-09-2013, 05:20 AM
  3. Can bath sink and utility sink drain into 1.5"...PHOTOS
    By Hammerlane in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-16-2012, 01:02 PM
  4. Can I tie my bathroom sink and utility sink drains together? As well as vent?
    By vinceliberto in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-21-2010, 06:02 AM
  5. Question on drain for utility sink install in basement
    By Fastgt79 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-14-2009, 07:20 PM
