Results 1 to 2 of 2
Thread: Drip question...emitter tubing
    DIY Junior Member pmsmith2032's Avatar
    Apr 2013
    Burbs of Chicago
    Default Drip question...emitter tubing
    Can anyone tell me if I can connect 1/4" solid tubing (running to individual emitters) from 1/2" emitter tubing (with holes spaced every 18")? Is it possible to plug holes in the 1/2" emitter tubing in areas where there are no plants? Thanks!
    Mar 2011
    Houston, TX
    Quote Originally Posted by pmsmith2032 View Post
    If the 1/2 inch is closed on its end then yes. Or if it is at line pressure. The flow rate of what is on its end maters.
    Look at the flow rate that you need for each emitter, then use a calculator to see how many you can use on the same line.
    Yes you can close unused ones , or use 1/4 inch at that point for a different feed, given that you keep the flow rate in spec.
    Good Luck.
  1. Toto Soiree Toilet: Drip, Drip, Drip?
    By Philip in Connecticut in forum Toilet Forum discussions
    Last Post: 11-16-2013, 10:06 PM
  2. Hose/tubing for drip systems
    By blown in forum Irrigation / Sprinkler Forum
    Last Post: 10-11-2010, 11:20 AM
  3. Drip, Drip, Drip from my shower head
    By miranda12 in forum Shower & bathtub Forum & Blog
    Last Post: 10-17-2006, 01:49 PM
  4. drain flange--drip,drip,drip
    By rockjet in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2006, 03:39 PM
  5. question about soldering copper tubing
    By bardos in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-24-2006, 04:53 AM
