Results 1 to 5 of 5
Thread: Pulling 100 ft. deep 2 inch packer well
    DIY Junior Member homesteader's Avatar
    May 2013
    louisiana
    Default Pulling 100 ft. deep 2 inch packer well
    I have a 100 ft. deep 2 inch packer well with a 1 inch drop pipe. casing and drop pipe are
    galvinized. the well was dug in 1962, has not been used for about 40 yrs. I attempted to
    pull the drop pipe, will not budge or turn. pored 1 gallon of chlorex between drop pipe and 2 inch
    casing, still stuck. Any suggestions would be greatly appreciated.
    thanks
    Moderator valveman's Avatar
    Mar 2006
    Packers are not easy to pull. You will probably need a good hoist.
    May 2013
    louisiana
    valveman:
    thank you for your suggestion.
    I attached a cross member at the top of the drop pipe and put a hydrylic jack under
    each end. I'am afraid if I apply more pressure it may break?
    is there anything I can pore down the 2 inch casing to loosen the leathers?
    thanks
    homesteader
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    After 50 years you need a good hoist truck and hope the pipe doesn't pull apart
    Mar 2006
    Quote Originally Posted by craigpump View Post
    Yeah this is what I meant also.
  1. 2 inch packer ejector stuck in well
    By DonL in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-28-2011, 05:40 AM
  2. Pulling a deep well pump
    By rubocop in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-02-2009, 11:55 AM
  3. 3 inch well casing. submersible/packer/?
    By Barnes in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-15-2008, 08:03 AM
  4. 2 inch packer ???????
    By jgmap in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-07-2007, 05:05 PM
  5. 2 inch single pipe packer diagram
    By sucker dave in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-11-2006, 02:55 PM
