Results 1 to 2 of 2
Thread: Can't disconnect Supply line from Toilet tank
    DIY Junior Member Cindyono's Avatar
    May 2013
    CT
    Default Can't disconnect Supply line from Toilet tank
    We are homeowners attempting some DIY projects in our bathroom. We are replacing a leaky supply line on our toilet. Haven't gotten too far, because we can't get the old supply line disconnected. I attached pictures. I am not sure if I have the names correctly, but the Coupling Nut (the larger one below the locking nut) won't budge. Should that locking nut be tight again the tank, then loosen the coupling nut? We have tried using 2 wrenches, but the nut won't budge and we don't want to crack the tank.Name:  2013 sink 002.jpg
Size:  26.7 KBName:  2013 sink 001.jpg
    The large nut snugs the copper riser to the end of the fill valve.
    The thin nut secures the fill valve in the tank.
    These nuts are upside down. So make sure you are loosening them, not making them tighter. Just undo the large nut and it will drop down.
  1. Toilet Supply Line
    By KShirriff in forum Toilet Forum discussions
    Last Post: 11-10-2012, 01:28 PM
  2. HELP GUYS !!! Air in lines: bad tank ? crack in supply line ?
    By JimPlumbs in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-16-2011, 08:23 PM
  3. Supply Line to Tank Size
    By Designie in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-16-2010, 06:23 AM
  4. Best toilet supply line.
    By Guest in forum Toilet Forum discussions
    Last Post: 01-16-2008, 04:58 PM
  5. Replacing Toilet supply line
    By gtmtnbiker in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-07-2008, 08:21 PM
