Results 1 to 15 of 42
Thread: Trying to rig a variac switch to slowing raise the voltage on an old tube amp
Hybrid View
    DIY Senior Member CanOfWorms's Avatar
    Feb 2013
    New Jersey
    Default Trying to rig a variac switch to slowing raise the voltage on an old tube amp
    One person told me to put a 100w bulb in the series:
    Is this the correct layout?
    Does anyone know if I can just use a three pole dimmer switch.
    Name:  rigged variac.jpg
    Mar 2011
    Long Island, NY
    Quote Originally Posted by CanOfWorms View Post
    What you got here is not a Variac, and 100 watt light bulb will limit the final power to 100 watts.the output of a light dimmer switch is not intended to feed an electronic device, especially if it has a transformer in it.
    A real Variac can do what you want, but putting too low a voltage into the amplifier may damage (fry) it. Depends, and not the wearable type.
    Feb 2013
    New Jersey
    Well the pupose of this is to gradually start up an old tube amp that may have not been run in years.
    The idea and (what a few tube repair guys have told me) is that by gradually increasing the voltage the electrolytic capacitors will "reform" instead of blowing.
    The procedure using a variac is to run it for a minute at low voltage gradually increasing to full voltage over 5 minutes.
    There are a few types of dimmers. The one I think I need is the variable voltage one that you might use on a ceiling fan.
    Thank you for explaining what the light bulb would do.
    Mar 2011
    Long Island, NY
    I can certainly understand that you want to baby those electrolytics.
    Feb 2013
    New Jersey
    Thank you that made me smile, even If I didn't quite catch your drift.
    DIY scratch-pad engineer leejosepho's Avatar
    Nov 2006
    Putting a string of light bulbs (or any other resistance load) in series will reduce the voltage at the end...
    black: ---o---o---o---< put your multimeter leads
    white: ---------------< here to see what you get
    ...and changing bulbs with different wattages will affect the voltage at the end. So, set up three 100-watt bulbs is series and see what voltage you get at the end of the line, then experiment just a bit with more, fewer and/or different bulbs until you can get the voltages you want at the end...then put your old amp in place of the multimeter.
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
    DIY Junior Member John in herndon's Avatar
    May 2007
    VA
    Default Using a Variac® to gradually raise the voltage in a tube amp
    I used to be in the audio repair business and used this technique all the time on both tube and solid state amps. It prevents doing a lot of damage if you didn't find all the blown components.
    That said, you have to use a VARIAC® or variable autoformer to do this because this preserves the sine wave of the AC power. Solid state dimmers do not do this. They use SCRs and TRIACs to vary the voltage by delaying the turn on point of each individual cycle of the AC waveform. The result is a non sinusoidal waveform which would not work to power an amplifier or other electronic device.
    If it doesn't weigh 10 pounds or more it is not a transformer and won't work.
    Mar 2011
    Houston, TX
    Quote Originally Posted by John in herndon View Post
    You can use a variable high power resistor also, If you do not need isolation from the mains using a transformer.
    I never have seen a DC transformer that lasted very long. They do not like chopped DC, unless they are designed for it.
    I use a light bulb in series with the AC line and it gives a good indication of your situation.
    Have Fun.
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    Besides seconding the "use a genuine variable transformer" advice, there is also a caution for some circuitry, where it can actually be advisable to construct a replacement for a rectifier tube, using solid-state components and a tube-base connector. I don't have more details at my fingertips, but I know the idea behind the temporary replacement was that the initial low voltage applied in a series of several steps was not going to be enough to make a rectifier tube functional, and the solid-state replacement would function with any input voltage applied to the tube device's power transformer.
  1. Why do I have voltage when switch is off?
    By Randyj in forum Electrical Forum discussion & Blog
    Last Post: 04-28-2011, 01:42 PM
  2. Flickering lights on circuit with low voltage and line voltage bulbs
    By davidwie in forum Electrical Forum discussion & Blog
    Last Post: 04-18-2011, 07:34 AM
  3. Wall Socket With Voltage AND No Voltage? HELP!
    By jackvogel in forum Electrical Forum discussion & Blog
    Last Post: 12-23-2010, 07:41 AM
  4. Running low voltage in high voltage boxes
    By Ian Gills in forum Electrical Forum discussion & Blog
    Last Post: 08-22-2009, 07:27 PM
  5. Installed new low voltage recessed lights - now switch hums
    By taysan in forum Electrical Forum discussion & Blog
    Last Post: 05-02-2008, 04:39 PM
