Results 1 to 2 of 2
Thread: Steel to Copper Union With a Plastic Fitting
    DIY Junior Member dlipter's Avatar
    May 2013
    NY
    Question Galvanized Steel to Copper Union With a Plastic Quick Connect Fitting
    I have a Watts (SeaTech) WaterPex 3/4" CTS x 3/4 MPT plastic fitting. Can this be used in place of a dielectric union between galvanized steel & copper? The 3/4" MPT side would screw into a steel female thread, and the other side would accept 3/4" copper pipe (quick connect). Since the fitting is plastic, and the two dissimilar metals don't touch, isn't this a defacto dielectric union?
    Technically, yes. But since the "electrolysis" is conducted THROUGH the water, the proximity of the two metals is just as important as whether they actually touch. This is also the reason why most "dielectric unions" are cosmetic rather than functional, as would yours.
  1. 1 inch brass union compression fitting?
    By cmose in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-25-2012, 10:52 AM
  2. What kind of union fitting is this? Ford Fitting
    By DavidTu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2011, 10:25 PM
  3. plastic or stainless steel motor support?
    By panda in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-06-2011, 12:43 PM
  4. How to replace a copper fitting close to another fitting
    By jfhardy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-26-2008, 08:48 AM
  5. Connecting plastic pipe to galv. steel
    By Mike B in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-19-2007, 04:04 PM
