Results 1 to 2 of 2
Thread: Drain connection for shower enclosure
    DIY Junior Member Shirtgames2011's Avatar
    May 2013
    NY
    Default Drain connection for shower enclosure
    I am installing a 60" fiberglass shower enclosure. The drain is a no solder Oatey PVC. The 2" PVC drain pipe connects between the Oatey drain and the trap. I do not have access from below the shower base as I am on a slab.
    My question is if I need to glue the connection at the trap or can I just insert the 2" pipe into the PVC trap?
    Jan 2008
    All of the PVC joints must be primed and cemented. You want to use the Oatey No-Calk drain. It uses a rubber compression ring to seal the shower drain to the drain pipe.
  1. Leak in 1958 shower enclosure:
    By oldberkeley in forum Shower & bathtub Forum & Blog
    Last Post: 10-12-2011, 05:40 PM
  2. Frameless Shower Enclosure
    By Kathristin in forum Shower & bathtub Forum & Blog
    Last Post: 10-15-2008, 03:29 AM
  3. Need shower enclosure for narrow area 24W x 40 L?
    By amenez in forum Shower & bathtub Forum & Blog
    Last Post: 08-28-2008, 06:42 PM
  4. fiberglass shower tub enclosure
    By johnnj2000 in forum Shower & bathtub Forum & Blog
    Last Post: 06-21-2006, 07:12 PM
  5. changing shower enclosure
    By toni in forum Shower & bathtub Forum & Blog
    Last Post: 05-01-2005, 01:18 PM
