Thread: water leak at supply line hole in foundation
    DIY Junior Member MartGio's Avatar
    May 2013
    St. Louis, Mo.
    Default water leak at supply line hole in foundation
    I have water dripping in during heavy rain where the water supply line comes thru the foundation. Outside is underground with a large concrete porch across front of house. MartGio.
    I would use water plug cement. This fast setting cement is made to plug cracks and hole even with there is water running. You mix a small amount with water to make a stiff dough. Then push the dough into the hole or crack. Cracks should be chiseled out a bit. I believe the directions say to make a / \ notch, but I've found that is a bit hard to do and just opening the crack a bit will work. Mix only a small amount at a time and work fast as the setup time is very short and once is starts to harden, you can not add water so you may need to use several small batches rather than just one larger one. If I remember correctly, "Waterplug" is a brand name, but a decent hardware store should be able to point you to their brand of product.
    May 2013
    St. Louis, Mo.
    Ok, thanks for your answer, maybe not to bad of a problem to fix, THANKS!
    Not so difficult, but do use rubber gloves handling the cement. It's got a lot of lime in it and can irritate or even burn your hands.
  1. Basement Leak from small hole in concrete foundation floor.
    By bjferri in forum Remodel Forum & Blog
    Last Post: 08-25-2011, 12:31 AM
  2. Minimum diameter for a hole in the floor for a water supply line?
    By JMichael in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-05-2010, 01:42 PM
  3. leak at water supply line and toilet
    By closer in forum Toilet Forum discussions
    Last Post: 12-14-2006, 10:57 AM
  4. hydraulic cement - foundation leak - supply pipe
    By dave007 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-29-2006, 09:42 AM
  5. leak from rain where water supply enters foundation
    By fjbuono in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-08-2005, 11:17 AM
