Results 1 to 8 of 8
Thread: Rheem 21vp75E-1 water heater will not light
    DIY Junior Member Brendan1989's Avatar
    May 2013
    Chicago
    Default Rheem 21vp75E-1 water heater will not light
    Two weeks ago I got 3 feet of water in my basement due to flooding. I got my direct vent water heater working after about 3 days of drying out. The WH worked for about 10 days. This morning my daughter told me that there's no hot water. The fan motor is running but there is no flame. Does anyone have any ideas?
    Jan 2008
    When the controls of a gas appliance have been submerged, they should no longer be considered safe for reuse. If you have any insurance, they will often pay a damage claim for your loss.
    It may have taken awhile for that moisture to migrate into the working parts, and they're now rusted or corroded. As said, there are no gas-fired valves that are considered safe after they've been submerged - the valve, if not the tank, should be considered a flood loss.
    May 2013
    Chicago
    It is not covered by insurance--I checked. FEMA has not made a final decision if they will provide some relief. I unplugged the unit for about 3 hours and plugged it back in and it fired up.
    Mar 2011
    Houston, TX
    Quote Originally Posted by Brendan1989 View Post
    That does not mean that it is safe. If it stops again then it is hosed, for the long run.
    Please do not blow yourself or your family up, just because FEMA will not pay for it.
    Good Luck.
    Covered by insurance, FEMA, or anything else is moot. There is NO WAY it can be ever be made safe for use.
    FWIW, assuming you have a gas furnace, it may be toast as well...I'll say it again, NO residential gas fired appliance is considered safe if it has been submerged.
    May 2013
    Chicago
    I got it working. The control board and the air flow switch are now new. Honeywell does not make the identical control board so I brought their universal replacement control board. I then cleaned the igniter with a wire brush. Thanks to everyone who was so encouraging about the ability to reuse this water heater...stay green...
  1. Rheem Water Heater has me stumped!
    By lizzydog in forum Water Heater Forum, Tanks
    Last Post: 05-09-2009, 06:59 PM
  2. GE/Rheem hot water heater fails after 5 years??
    By fleetwood in forum Water Heater Forum, Tanks
    Last Post: 05-06-2009, 07:13 AM
  3. <<<<Rheem Gas water heater HELP>>>
    By Jayshiv_patel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-25-2008, 07:09 PM
  4. which rheem water heater???
    By popawheelie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-29-2007, 03:06 PM
  5. Rheem 30 Gal. Water Heater
    By Bigmike in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-21-2007, 03:00 PM
