Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Hot water recirc loop issues
  1. #16
    quote; the local winnelson backed up the plumber's plumbing-
    That is like saying you went to Home Depot and the guy in the aisle said it was done correctly. Do you REALLY believe that someone working the Winnelson counter actually worked as a plumber and then "downgraded"?
  2. #17
    DIY Junior Member Kendal's Avatar
    Aug 2012
    Nashville, TN
    HAHA! No, my point exactly--and also that my plumber buys stuff there! What else are they going to say And hence why I came to this forum! But truly, saying that any licensed plumber is great is like saying every licensed general contractor is great. I mean, no one's EVER had any problems with one of those, right? Here's the rub in all this...this was inspected and passed! I'm glad I paid for that...
  3. #18
    I don't believe it's in the code book that the check valve is "required" on the recirc, but if you leave it out, the cold water goes backwards up the line.
    You know that now too. And I'm guessing your plumber is putting that new knowledge on his check list.
    We install the check valve, not because it's code, but because it's a better way. I use a spring check, as they make less noise while the pump is running than using a swing check.
  1. Any way to have a gravity recirc loop with a tankless water heater?
    By benze in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-08-2012, 03:32 PM
  2. Gravity recirc loop strange problem
    Last Post: 03-21-2012, 08:41 PM
  3. recirc loop ok can't add branch
    By den in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-15-2007, 06:38 AM
  4. Gravity fed recirc loop question.
    By neverman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-05-2006, 06:34 AM
  5. hot water recirc loop
    By shineer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-01-2005, 08:16 AM
