Results 1 to 1 of 1
Thread: Pressure Balancing Valve
    DIY Junior Member ceiiinosssttuu's Avatar
    Apr 2013
    Idaho
    Default Building a new master shower with antique-looking exposed copper plumbing
    Hi, I am building my own house and roughing in my master shower. I want dual shower heads with an antique, industrial look with exposed copper shower plumbing (see diagram). Initially I ran 1/2" pex, but I was told I would need more volume for a dual shower, so I ran another set of 1/2" pex (it was easier than running 3/4 since I already had a 3/4"-to-1/2" manifold). So now I have two 1/2" pex hot lines and two 1/2" pex cold lines that I need to connect back together with a pressure balancing valve (per code). Would either of the ideas in the diagram work? Which is better? Is there a better idea I'm not thinking of?
    Thank you!Name:  Shower Plumbing Diagram.jpg
  1. Grohe Pressure Balancing Rough-In Valve
    By CTerhune in forum Shower & bathtub Forum & Blog
    Last Post: 02-20-2011, 10:14 AM
  2. Pressure Balancing Valve Output
    By bbradski in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-15-2009, 07:53 PM
  3. Pressure balancing valve stuck
    By zone29 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-19-2008, 06:34 AM
  4. Trouble with pressure balancing valve
    By jasdyer in forum Shower & bathtub Forum & Blog
    Last Post: 05-04-2008, 08:14 PM
  5. Pressure balancing valve problem
    By Bill_R in forum Shower & bathtub Forum & Blog
    Last Post: 02-25-2006, 01:41 PM
