Results 1 to 6 of 6
Thread: How attach a new shower body valve
    DIY Junior Member Msisell's Avatar
    Apr 2013
    Minnesota
    Default How attach a new shower body valve
    It sounds simple to do but when I got the new shower kit the valve part does not have flanges with screw holes to attach it. How do I set it in to stay securely?
    Apr 2013
    Minnesota
    I could post a picture if I knew how???
    DIY Junior Member penobscotman's Avatar
    Mar 2013
    Buffalo NY
    I just did this with a Moen valve and, like you, was looking for flanges. However the directions show the valve supported by the supply lines, copper in my case. That has worked fine. My trouble was visualizing the spacing fore-and-aft in the stud cavity. The directions were nearly useless and designed for someone replacing the faucet rather than doing it as new work from scratch.
    What's your situation?
    Apr 2013
    Minnesota
    That's the exact situation for me... Directions useless. So far I put a stud in horizontally and was going to "zip tie" it in place. I just can't imagine it staying in place otherwise?? Thank you for your input!
    Use some copper pipe straps on a brace screwed behind the valve to the supply lines. If your pipes go horizontally through studs, the holes will help stabilize things, but not enough.
    Apr 2013
    Minnesota
    Great! Thanks!
  1. Help with bath/shower valve body
    By shaps in forum Shower & bathtub Forum & Blog
    Last Post: 02-07-2010, 05:14 PM
  2. reuse of tub/shower valve body
    By tbb2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-02-2009, 07:39 AM
  3. delta shower valve body - no water
    By jrburt in forum Shower & bathtub Forum & Blog
    Last Post: 05-21-2008, 04:56 PM
  4. Shower Valve Body Installation (NPT)
    By hans_idle in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-25-2008, 08:06 AM
  5. how to install a new valve body in tub and shower
    By don wagner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-31-2006, 08:51 PM
