Results 1 to 6 of 6
Thread: Faucet change
    DIY Junior Member stephnej's Avatar
    Nov 2004
    Florida
    Default Faucet change
    Faucet change
    I have a Jacuzzi tub and it is leaking slowly at the spout and at the valve. I wanted to get a new handle. so, will any handle fit the tub? it is a pull out handle now and I wanted to upgrade it. is it a matter of taking out the old one and putting a new one in? or is it more involved? I see the spout is easy. just unscrew and put another. what do you all think?
    Stephen
    Faucets parts are definitely NOT universal. You need to determine the exact make and model of your faucet and get the excact replacement parts.
    Plumber, Contractor, Attorney LonnythePlumber's Avatar
    Wichita, Kansas
    Default Replacing vs. Repair
    Stephen, I presume you realize that replacing a spout doesn't keep it from leaking out the end.
    Nov 2004
    Florida
    LonnythePlumber
    No, why is it leaking? is it because of a worn washer?
    Wichita, Kansas
    Default Washer
    Yes it is a washer or a cartridge. Handles control the on and off of the water. Their parts get worn and allow some water to get past and come out the end of the spout. If the water is coming out around the handles then it is the o rings that have become worn. It would be a value if you could post a picture of your faucet.
    Nov 2004
    Florida
    Lonny, thanks. as a matter of fact I just purchased a digital camera and will be taking many pics and posting them along with questions. like they say, " A picture is like a thousand words".
    yes, the faucet is dripping at the handle and the spout, "double trouble".
