Results 1 to 2 of 2
Thread: "proper" method of bullnose around tub/shower surround?
    DIY Junior Member rkhanso's Avatar
    Feb 2010
    MN
    Default "proper" method of bullnose around tub/shower surround?
    I am putting some 4.25" ceramic tile above the tub/shower surround in my kids' bathroom. I was wondering what the standard or proper way to align the bullnose in respects to everything else. The bullnose I have is 6" tall, not 4.25"
    Does the bullnose start with a full piece at the ceiling and then the bottom piece get cut to fit? Or the other way round?
    Also, I saw 4.25" square tile with a bullnose edge at the store, too. I wouldn't use that square bullnose above the shower surround and then the longer 6" on the side of the surround?
    Or, am I off in using the 6" bullnose on the side in the first place. Is this not usually done?
    Here's a picture:
    In the Trades kevinp's Avatar
    Apr 2013
    Missouri
    You don't want to mix two different size bullnose tile there, 6" is fine. The top is the most visible so starting with a full bn tile at the top is a good idea unless it leaves a small piece at the bottom. Do the layout the way it pleases you the most.
    Kevin Pridemore
    KPC Tile & Stone
    www.kpctileandstone.com
    Sinkits MS LLC
    www.sinkits.com
  1. Frozen Kinetico, options/questions on "proper" install
    By dyeager535 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-25-2011, 10:36 AM
  2. shower drain forSterling 48" shower surround
    By timwise999 in forum Shower & bathtub Forum & Blog
    Last Post: 01-06-2011, 09:10 PM
  3. "Proper Handling" of Threaded PVC Joints
    By baumgrenze in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-22-2010, 11:51 AM
  4. Need help with Alternate Method of pumping in two-well "pump & dump" systems?
    By Thumper in forum Solar and Geothermal Water Heating Forum
    Last Post: 04-20-2009, 10:21 AM
  5. Proper Caulk/sealant for shower surround
    By dprocket in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-31-2009, 09:41 AM
