Results 1 to 6 of 6
Thread: 1/32 inch gap between enclosure walls and receptor
    DIY Junior Member penobscotman's Avatar
    Mar 2013
    Buffalo NY
    Default 1/32 inch gap between enclosure walls and receptor
    Sterling says there should be no more than a 1/32 inch gap between the walls and the receptor. But whatever gap there is seems to be determined by the contact between the receptor flange and the pin thingy on the back wall. They butt, are coplaner. The woman on the help line suggested that the pin gizmo is supposed to slide behind the receptor flange, but I don't believe this. By lots of wiggling I was able to reduce the gap to < 1/32 (supposedly 2 credit cards thickness), but this was actually accomplished by grinding down the contact a bit between back wall and receptor flange.
    Why is there a gap at all? Shouldn't the parts be absolutely tight against each other? Sterling says to caulk only the front 4 inches of the wall to receptor seam. Is there any harm in caulking all of it?
    Jan 2008
    It might help if you told us which unit you were installing.
    Mar 2013
    Buffalo NY
    Sorry. It's a Kohler/Sterling "Advantage" shower enclusure. Vikrell. Three walls and a pan/receptor. 32X36. Everything snaps together and it looks as if the joints are arranged to drain. But they aren't not tight like solvent-glued PVC.
    Mar 2013
    Buffalo NY
    I know these are lame questions, but the problem is that I don't really understand how these enclosures for tubs and showers work to keep water in. Something sits on top of something else. The join is shaped like flashing, at least that is how I visualize the cross-section. So any water that gets in the gap drains down and out rather than rising up the flange against the wall. We are depending on gravity, not caulk.
    Is my interpretation correct?
    Jan 2008
    The installation of these showers is very dependent on the rough framing being perfectly straight and square, and the pan being perfectly level. A good quality 72" box level should be your best friend when framing for this.
    Your reference to flashing and gravity is correct. If you look closely where water can and can't go, you will see why you are not to caulk, except where the instructions specify.
    Mar 2013
    Buffalo NY
    The shower is in with the framing as good as I could get it. I did have to shim here and there. Ideally I would have used perfectly straight 2X4's, but even with picking at the lumber yard this was an elusive goal. Thanks for your help.
  1. 1/32 inch gap between enclosure walls and receptor
    By penobscotman in forum Shower & bathtub Forum & Blog
    Last Post: 04-30-2013, 09:37 AM
  2. 10 inch toilet in 12 inch rough in - tank brace suggestions?
    By zsuguru in forum Toilet Forum discussions
    Last Post: 02-02-2013, 07:58 PM
  3. we have a 16 inch rough-in andcannot find a tolet ith a 16 inch roughin anywhere
    By nancyann in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-17-2011, 04:22 PM
  4. Cable tool or bore drill? 5 inch pvc or 4 inch steel?
    By Barnes in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-16-2008, 05:48 AM
  5. Is anyone familiar with Swanstone solid surface walls for bathtub/shower walls?
    By bjferri in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-25-2007, 09:36 AM
