Thread: Need a reliable three hole kitchen faucet
    DIY Junior Member E. Williams's Avatar
    Mar 2013
    San Antonio, TX
    Default Need a reliable three hole kitchen faucet
    I am replacing a Koehler Forte which is leaking for the third time. I just had a plumber here who wanted to charge $450 for a Moen that was listed on their site for $142. I want a dependable polished nickel three hole with side sprayer. Any suggestions?
    Polished nickel finishes will cost more than the more typical chrome. Most any brand will make a single-handle faucet - it will either come with or have an optional plate to cover the existing holes. Finding one with two valves and the spout for a 3-hole sink requires knowing the spacing of the holes. Personally, I prefer a single handle to get the desired volume and temp. This type of replacement normally isn't a huge effort, and many DIY'ers are capable of doing it themselves. It can be a pain if the nuts (assuming the existing valves have nuts on the bottom) are rusted, but some single handle ones unscrew from the top, then slide out from the bottom. A basin wrench doesn't cost much, should you need one, but sometimes, you have to cut the foolish things off, and that can be awkward. This type of wrench has a long shaft to reach up behind the sink to loosen (or tighten) the nuts, should the valve have them (some use a clamp and a screw). You should also replace the shutoffs at the wall if they are old; preferably with 1/4-turn ball valves. That price would seem to equate to about a 2-2.5hours of labor with the faucet and incidentals. It might take you that long, but most pros would be done quicker. My mother had a similar faucet that was replaced with a tall, single handle pullout spout. To fill the side sprayer hole, we bought a soap dispenser that matched. It came with the plate to cover the other holes. This was a Delta, but Moen is good, too. I have a Grohe in my home that's been working fine for about 10-years now.
    ALL kitchen sinks have the same 8" c/c dimension so your only task is to find a faucet you like. Delta and Pfister both make "two handle" faucets which are reliable and easily serviced with readily available parts.
  1. Reliable Tub/Drain Overflow Units - Which brands are reliable
    By chefwong in forum Shower & bathtub Forum & Blog
    Last Post: 06-15-2011, 05:20 PM
  2. Kitchen Sink Hole Repair Help.
    By ckranez in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-20-2011, 05:01 PM
  3. size hole for single hole faucet
    By bobbieK in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2009, 01:31 PM
  4. Moen Kitchen Faucet Leaking on 3 Hole Sink
    By kornbln in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-01-2008, 04:01 AM
  5. Reliable Kitchen Sink Garbage Disposal ??
    By florida_wen in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-13-2005, 03:39 PM
