Thread: Pressure relief valve failed.
    DIY Junior Member James W's Avatar
    Oct 2009
    Richmond BC
    Default Pressure relief valve failed.
    We werE woken up a few nights ago by a pretty loud water hammer. Happened 2 or three more times that night. No water running so know of "spontaneous". Checked everything out and ended up fiddling with the water pressure on the PRV (an old Honeywell). This reduced the severity but still get a hammering. Interestingly it starts when you open a tap, and continues for 2 - 3 minutes after shut off. Not every time but often. My best trouble shooting guess is a bad PRV that is allowing pressure fluctuations in the line. You can feel the vibration in the feed line just downstream from the valve, and if you shut off the water supply tap the vibration stops. This is GPS g to be. 700+ dollar replacement so I'd appreciate Ny advice on how to conform my diagnosis
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    If is a honeywell bruckman you can get a repair cartridge remove top and old center cartridge, reinstall top and you are finished
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Oct 2009
    Richmond BC
    That would great. Don't know about Brickman, it is a Do6f -probably as old as the house 1978
  1. Necessity of Vacuum Relief Valve - Not Pressure Relief Valve
    By WillieK in forum Water Heater Forum, Tanks
    Last Post: 11-17-2013, 09:58 AM
  2. pressure relief valve
    By rbig in forum Irrigation / Sprinkler Forum
    Last Post: 05-24-2010, 11:12 AM
  3. Pressure relief valve bad?
    By billy_pilgrim in forum Boiler Forum
    Last Post: 07-09-2009, 01:09 PM
  4. Failed Wilkins Model 600 Pressure Reducing Valve ???
    By roback in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-16-2008, 08:40 AM
  5. Pressure Relief Valve
    By terrell44 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2005, 11:25 AM
