Results 1 to 5 of 5
Thread: Inserting a sanitary tee into existing stack that will not move
    DIY Junior Member denikar's Avatar
    Feb 2013
    Canton, MI
    Default Inserting a sanitary tee into existing stack that will not move
    I'm investigating how to insert a sanitary tee into an existing vertical 3" stack that will not budge at all (vertically). One of the discussions I found here suggested cementing the lower part of the santee and using a fernco fitting for the top part. Is this the recommended method or are there better alternate methods?
    Thanks,
    Tim
    Normally it takes two of these
    Notice the stainless steel wrap that prevents the pipe from shifting?
    Feb 2013
    Canton, MI
    Thanks Terry
    If it does not move, there is no way you could "cement the bottom and use a transition coupling on the top", because you would have to cut out enough pipe to angle the Y in, then slide it down, and then whatever you are using would be too short to fill the gap.
    Feb 2013
    Canton, MI
    To clarify, the cut stack can be moved enough in the x-y direction, just not up and down (z direction).
  1. Inserting tee in existing PVC pipe
    By vivona in forum Irrigation / Sprinkler Forum
    Last Post: 08-31-2010, 08:07 PM
  2. House stack - move and enclose
    By bikewimp in forum Remodel Forum & Blog
    Last Post: 10-25-2008, 07:49 AM
  3. Main Sanitary Stack Code Question
    By seaneys in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-15-2007, 10:24 PM
  4. Can I move an existing AAV?
    By n00bie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-08-2007, 10:33 AM
  5. Inserting a Tee into an existing copper line
    By darmstro in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-17-2007, 07:20 PM
