Thread: Useless online vendor, help with 7000 3 cu ft. settings please
    DIY Junior Member Acropora's Avatar
    Apr 2013
    Michigan
    Default Useless online vendor, help with 7000 3 cu ft. settings please
    Hi, would appreciate guidance for 96k sxt7000 unit settings. Works ok except after regeneration we seem to have untreated water breakthrough. Tried getting a softener locally but couldn't get a quote less than $1K over the online price and the online guys are useless.
    Have 4 kids and we use about 3-400gal a day of water that's 30 hardness and 2 iron, so about 38 hardness.
    Seems to use a lot more salt/mo than our old 22k softener but supposedly not a unit that was recalled.
    BLFC is 0.125. C-800F resin. If this was your softener what settings would you guys run?
    Thank you!!! Current settings
    VT dF26
    CT Fd
    C 96
    H 38
    RS SF
    SF 15
    DO 10
    RT 2:00
    B1 10
    BD 50
    B2 8
    RR 10
    BF 30
    FM t1.2
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    I would change the following: VT ST2b, C 60, RS cr BF 48.
    You are getting hardness because the unit is set for 96K but the salt dose is only 11.25 lb salt and should be 60K @ 18 lb salt.
    Apr 2013
    Michigan
    Thanks for the info! Unfortunately the softener won't do st2b it appears. The only time we have hard water is right after the unit regenerates. Somehow it's not flushing the normal water out during the backwash I guess? Was wondering why we're going thru 40# of salt a week also.
    Jan 2012
    California
    St2b and df2b are the same.
    Fast rinse is designed to give you perfect soft water after regeneration,
    What injector do you have? What Drain line flow control size? The trace amounts of hard water after regeneration should hardly be noticable, if at all.
  1. New 7000 SXT. Not sure about it.
    By jamms in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-26-2013, 07:51 PM
  2. Replies: 1
    Last Post: 11-29-2011, 11:51 AM
  3. Vendor - Client relationship
    By Terry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-06-2011, 04:57 PM
  4. Replies: 0
    Last Post: 11-19-2010, 05:21 PM
  5. McCafee Is Useless!!
    By Kiko in forum Computers and Stuff
    Last Post: 08-16-2010, 08:39 AM
