Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Solar pool heater. Should I cover?
  1. #16
    In the trades Dana's Avatar
    Jan 2009
    You want the difference in temperature between the water coming into the collector and what's flowing out to be 20F or less (eg: 68F pool water, 88F water coming out of the collector), but if the delta is much less than 10F you're probably chewing up more pumping power than it's worth. It depends on the absolute efficiency of the pump.
  2. #17
    DIY Senior Member CanOfWorms's Avatar
    Feb 2013
    New Jersey
    Quote Originally Posted by Dana View Post
    Last year the system I had worked. And though I did not measure it, it was acceptable.
    But my wife wants it really hot. Like over 80.
    I have the black sprinkler pipe hooked up to black rubber garden hose with fittings.
    The pump had a reducer and fed into that.
    Last year I was always screwing around with it because of one thing or another.
    What kind of pump to I need to work with my hose diameters?
  3. #18
    DIY scratch-pad engineer leejosepho's Avatar
    Nov 2006
    Quote Originally Posted by CanOfWorms View Post
    90 is comfortable for me, and here is what I have done:
    That hose was fairly warm before I began sending the water through it, and now it is much cooler. Beginning water temperature was 84, and I suspect I will have 90 in a couple of hours.
    I am using an inexpensive pump and filter combo, but you might look for a TACO circulator:
    http://www.taco-hvac.com/en/products...nt_category=18
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
  1. How to access piping inside solar pool heater panels?
    By CowboyGP in forum Solar and Geothermal Water Heating Forum
    Last Post: 07-12-2012, 12:58 PM
  2. Swimming pool Heater..i.e. Heat pump query
    By shahnaimath in forum HVAC Heating & Cooling
    Last Post: 05-16-2011, 08:10 AM
  3. solar heat for inground pool
    By little buddy in forum Solar and Geothermal Water Heating Forum
    Last Post: 02-26-2009, 03:40 PM
  4. pool heater quits
    By blewis in forum HVAC Heating & Cooling
    Last Post: 05-16-2008, 08:54 PM
  5. Whistling Gas Line to Pool Heater
    By mchaney in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-23-2007, 06:32 AM
