Thread: Toto unifit on unlevel flange
    DIY Junior Member chenry3's Avatar
    Apr 2013
    WA
    Default Toto unifit on unlevel flange
    Hello,
    I have a basement flange that is not quite level - there is about a 1/3" vertical drop between the left side to the right side of the flange. My original plan was to use 1 (or maybe 2 if needed) sani seal rings on my toilet as I've read that they should be able to handle that amount of unlevelness.
    I've since started looking at the toto toilets (specifically a soiree) with the 10" unifit adapter. I've never used the unifit adapters before and I wanted to know how/if I would be able to use one given my uneven flange. From your pictures at http://www.terrylove.com/wc/unifit.htm it looks like it seals to the flange via bolts the same way a toilet does - but does the unifit use a generic seal or does it have it's own? Would I be able to level out the unift adapter so that the soiree toilet would work or should I loook at a non-unifit 10" rough in toilet with my original idea of making up the vertial difference with my ring seal?
    My other thought was that if the unifit pieces could pivot (I could get one that isn't glued? or cut and re-splice it?) between the toilet and the flange mouting parts I could mount the flange at an angle and rotate the toilet part that joint to be perfectly level for where the toilet attaches. Would that be possible?
    The unifit installs with any toilet seal.
    We've used wax, Sani-Seal and the fluidmaster waxless seal.
    Uneven flanges are more common than you think. We install all day long with stuff like that. And we install the unifit very often.
    We keep 10's and 14's in the van in case we need them.
    Apr 2013
    WA
    Terry -
    Awesome thank you for the info - and the amazingly fast response. Sounds like the unifit will work
  1. Unlevel Toto Drake!
    By Nancy0 in forum Toilet Forum discussions
    Last Post: 10-11-2012, 09:35 AM
  2. Optimal Flange Height for Toto Unifit
    By glnow in forum Toilet Forum discussions
    Last Post: 08-04-2011, 07:25 PM
  3. Toto Unifit or Flange Offset?
    By annlynn in forum Toilet Forum discussions
    Last Post: 06-22-2010, 06:27 PM
  4. Unifit and high toilet flange
    By kaffine in forum Toilet Forum discussions
    Last Post: 06-03-2010, 07:37 AM
  5. Unifit Flange Difficulties
    By Tenderpaw in forum Toilet Forum discussions
    Last Post: 01-23-2008, 06:14 PM
