Thread: 5600se Softener not working reliably - "volume remaining" not changing?
    DIY Junior Member CMGeorge's Avatar
    Apr 2013
    Wisconsin
    Default 5600se Softener not working reliably - "volume remaining" not changing?
    I have a softener with a 5600se valve on it, and it seems like I'm not getting soft water. I purchased my home about a year ago, and for about the first few months, everything seemed to be working properly, but then the salt level stopped going down in the brine tank, and about the same time, I also started seeing hard water residue forming on faucets and such.
    I thought perhaps it might be a salt bridge at the bottom of the brine tank, so earlier this week I emptied it out, cleaned it out as well as I could, and replaced all the old salt with new System Saver II pellets, and forced a regeneration cycle. Since then, I've been checking the indicator on the front, and despite us using water as normal (showers, doing laundry, using a dishwasher, etc.) the "volume remaining" of softened water has remained at the post-regeneration level of 650. The bypass valve is set to "service" and the "flow" light is on.
    Any suggestions?
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    It sounds like the meter or senor is not working. If you don't have a manual, you might find it here: http://www.pentairwatertreatment.com...ControlValves/
    Jan 2012
    California
    you can remove the sensor from the meter assembly. Run a small magnet up and down and see if the flow indicator light blinks.
    If it does. then your meter might not be functioning. The meter in the 5600/2510, etc, are fairly simple and relaible, but they are also expensive to replace.
  1. 1" PEX or 1" PVC when hooking up new softener?
    By JoshB-NC in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-23-2012, 09:55 AM
  2. Clack WS1 type softener-no suction-have tried "everything"
    By DOCSCANTLIN in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-27-2012, 03:10 AM
  3. Softener hookup issue - 1" bypass, 3/4" Main
    By adawg in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-23-2010, 02:09 PM
  4. "Wet" changing electric water heater elements.
    By ballvalve in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-08-2010, 11:01 AM
  5. Fleck 5600SE water softener programming
    By mulman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-06-2007, 08:00 AM
