Results 1 to 2 of 2
Thread: Primer Line for Laundry Floor Drain
    DIY Member handyman923's Avatar
    Nov 2006
    Portland, OR
    Default Primer Line for Laundry Floor Drain
    I am installing a floor drain in an upstairs laundry room and need to install a primer valve. The drain I am using has a trap primer port inlet on the side of the drain near the top. I am installing the primer valve under a nearby sink.
    In order to run a 1/2" line to the drain, I will need to cross two floor joists. Does the 1/2" line need to slope downhill toward the drain? Or can it go down and then back up to meet the drain? My problem with trying to slope it is that the holes in the floor joists will be very close to the edge of the joist, much less than 2".
    Thanks for any advice!
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Should not go down then back up. It would work but then you would have water trapped in the discharge line from the trap primer all the time.
    Does not have to be sloped, strait into your primmer tee is best.A 3/4 hole in the joist should be okay or a little larger than OD of the pipe.
  1. How to prep a laundry room floor with floor drain for tiling?
    By benze in forum Remodel Forum & Blog
    Last Post: 08-30-2010, 12:18 PM
  2. trap primer for the floor drain, Canada
    By simmy1919 in forum Canadian Plumbing Code Questions
    Last Post: 06-02-2010, 07:31 PM
  3. trap primer for the floor drain, Canada
    By simmy1919 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  4. Trap primer needed on unused floor drain?
    By karsc01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-02-2006, 09:11 AM
  5. adding floor drain for second floor laundry room
    By illinipdx in forum Remodel Forum & Blog
    Last Post: 01-12-2005, 08:51 PM
